J'ai remplacé la soudure de mes enceintes Wilson par cette soudure Mundorf Supreme 10% Silver et le résultat est remarquable. Plus de détails, une meilleure extension des basses et un peu plus de transparence dans l'ensemble.
Caution : this is a partial packaging. By ordering this product you will not receive the full coil shown on the picture, but a part (2m / 11.7 of it). You can get the full coil here.
Mundorf's Supreme Msolder welding wire is composed of 10% silver. It is indicated for advanced projects that require excellent conductivity (mounting tubes, cable assembly, silver / gold foil). The silver content is balanced by a flux ratio of (2.2.3).
Caution, melting point is 290°C / 554°F, which implies the need of a good soldering iron.
Type | welding wire |
Conditioning | 11.7g / 2m |
Wire Diameter | 1mm |
Flux | 2.5% 2.2.3 |
Melting point | 290 ° C / 554F |
Composition | |
S-Sn | 88.60% |
Cu | 1.80% |
Ag | 9.50% |
the | 0.10% |
Average votes 4.9 / 5 18 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Helder S.
denis L.
Szilard M.
Jean F.
Xavier P.
