USB-B Adapter Cable for DC 5.5 / 2.1mm Female Power Supply
Câble adaptateur USB-B pour alimentation Jack 5.5/2.1mm Femelle
Reference : 8332
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
This cable allows the data to be easily separated from the input power of the self-powered DACs. This product is ideal for injecting clean (non-noisy) current into any audio device using the 5V from the USB ports.
Features:
  • USB-B female / Male
  • Jack DC 5.5 / 2.1 Female
  • Length: 25cm
https://www.audiophonics.fr/images2/8332/8332_adaptateurUSB-Balimentationexterne_3.jpg
https://www.audiophonics.fr/images2/8332/8332_adaptateurUSB-Balimentationexterne_4.jpg
Example of use: It is possible to provide the U-SABRE with the 5V required by an external power supply
for the purpose of delivering the noise generated by switching power supplies commonly used in data processing.
https://www.audiophonics.fr/images2/8476/8332_audiophonics_usabre_cordon_alim_.jpg
https://www.audiophonics.fr/images2/8476/5807_audiophonics_u-sabre_alimentation_1.jpg
-Linear stabilized power supply 5V 5A V-DAC Black V3.0
Length (m)0.25
ShieldingNC
Section (mm²)N/A
ConnectorJack DC
Output voltage (V)NC
Output current (A)NC
Input voltage (V)N/A
Power SupplyNC
4 reviews
Well worth the investment
Definitely an improvement with my Chord Qutest when using with a linear power supply over the power from my iMac. Smoother mids & highs and no hash or artefacts. The Qutest requires constant 5V power to its USB port.
If your DAC only requires power for the initial USB handshake like my Topping D70, you can use any outside power source to make the connection then disconnect the power to this adapter after startup and leave the adapter in place, it will then only get data from your computer or other source.
Highly recommended!
This review has been posted for USB-B Adapter Cable for DC 5.5 / 2.1mm Female Power Supply
Petite correction
En fait, il n'y a pas besoin de cet adaptateur pour le DAC USB U-Sabre Audiophonics puisqu'il a déjà une prise pour alimentation externe. Petite correction pour ne pas semer la confusion.
Très bon petit produit
Ce petit câble correspond exactement à ce que j'attendais pour fournir à une carte son USB une alimentation externe et meilleure. Il convient aussi pour le petit DAC Audiophonics U-Sabre pourvu d'une prise pour alimentation externe. Je suis satisfait de mon achat.
produit de qualité
bonjour c'est un cable de fabrication artisanale de qualité de chez audiophonics qui vaut son pesant d'or ,encore merci pour ce conseil avisé pour mon systeme ,que du bon .......
