Linear Regulated Power Supply Module DC LT1084 4.9V to 24V 5A
Module d' Alimentation linéaire régulé DC LT1083 35V 7.5A
4.0 / 5
Reference : 8425
16,90 €tax incl.
14,08 € tax excl.
Shipping from France
Billing in France
Technical support in France
To help you choose the right feed for your projects, we invite you to consult this page.
Its particularly rigorous design and the quality of its components make it an excellent choice for powering any type of module or audio components requiring low voltage and clean power.
As many environments in which it contributes to improve the sound quality, equipped with a potentiometer it is possible to adjust its voltage from 4.9 to 24V.
Specifications:
  • Integrated discharge resistance
  • Output voltage adjustable by potentiometer
  • Input voltage: 2.5 to 20V AC
  • Output Voltage: Variable from 4.9 to 24V
  • Max. Output current: 5A (theoretical data as a function of dissipation)
  • Diodes : MBR1645
Features:
  • Height: 54 mm
  • Dimensions: 84 x 55 mm
  • Mounting hole spacings: 45 x 75 mm
  • Weight: 80 g
https://www.audiophonics.fr/images2/8425/8425_LINEAR_PSU_LT1083_1.jpg
https://www.audiophonics.fr/images2/8425/8425_LINEAR_PSU_LT1083_2.jpg
InputScrew terminals
OutputScrew terminals
Output voltage (V)35.0
Output current (A)5.0
Input voltage (V)5.0
Input voltage (V)3.0
Input voltage (V)25.0
Input voltage (V)10.0
Input voltage (V)20.0
Input voltage (V)26.0
Power SupplyRegulated Linear Power Supply
4 reviews
Module does not meet the specs!
Purchased the module, for use as regulated power supply at 32V.
But, unfortunately, the module cannot work at 32V, as the trimmer is running very hot when tuned at 32V, and on top, the electrolytic capacitors C3 and C4 are 25V types.
The operating voltage voltage at C4 is simply the output voltage.
When the VR trimmer is set at 32V, the voltage on VR is 27V, and VR is in that position abt 300 ohms : 2,5W dissipation is much too high...
To solve the problem, I adapted the module as follows:
Changed C3 and C4 by 64V types, and replaced R1 (50 Ohm) by 500 Ohm.
The module can now be easily tuned at the desired voltage, without burning the 5k trimmer, and blowing the elco's.
Daniel C. Hamme - Belgium
This review has been posted for Linear Regulated Power Supply Module DC LT1084 4.9V to 24V 5A
Condensateur occasion ?
Fonctionne parfaitement , mais esthétiquement le condensateur fait peur.
Rayer, bosselé, il doit etre à sa seconde vie.
Pour le prix, parfait !!!
Facile à mettre en oeuvre, parfait pour remplacer les prises CPL d'une box
excellent module à tout faire
très très bonne surprise: fabrication asiatique donc excellente qualité contrölée par les Taiwanais. Module très compact. Super rapport qualité/prix et surtout plus beaucoup plus rapide que d'arpenter les marchés de Guang Hua à Taipei ou de Huagiang Bei Lu à Shenzhen...
