MiniDSP HA-DSP DAC / Headphone amplifier SHARC DSP USB XMOS ES9018K2M
By buying this product you get 39 loyalty points
Reference : 12205
399,00 €tax incl.
332,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
MiniDSP HA-DSP 400MHz SHARC DSP XMOS ES9018K2M
DAC & Headphone Amplifier
MiniDSP HA-DSP
Revolutionary and Efficient
The HA-DSP is a brand new DAC / Headphone Amplifier of the brand MiniDSP. In addition to providing 3 inputs (USB / Analog / Toslink Optics), the HA-DSP provides digital audio processing power and unprecedented flexibility in a headphone amplifier.
Simple micro-bass and treble settings, 10 fully programmable EQ parameters per channel, and a FIR / Cross-Feed filter matrix that allows the installation of extremely sophisticated correction algorithms, this is what characterizes this MiniDSP headphone amplifier.
Components of HIGH quality
All this power is provided by a 500MHz XMOS multi-core processor and a 400MHz SHARC DSP. The embedded firmware is designed to have easy-to-use interface on laptops, desktops, iOS devices and Android.
Any other source can be connected via the analog input or
MiniDSP HA-DSP
Any other source can be connected via the analog input orthe optical digital input. As for USB audio transmission, this HA-DSP supports both PCM and DSD formats.
A DAC HIGH-END 32Bit in a case of aluminum
Designed in a lightweight and compact package, this MiniDSP HA-DSP can follow you wherever you want. Its 3300maH battery offers enough power for a listening session of at least 10h.
The combination of MiniDSP technology, careful selection of each component, and a high-quality ESS SABRE ES9018K2M DAC 32Bit make HA-DSP an unprecedented headphone amplifier.
Logo qobuzz audiophile streaming platform and testing of high-fidelity listening products
Qobuzissime award
Following the comprehensive test Qobuz platform, the DSP Ha was awarded the Qobuzissime award for its excellent audio performance.
Read the test here.
Connections: Inputs
Micro USB1x
USB-A1x
3.5mm Jack / Optical Digital1x
Connection: Output
Jack 3.5mm1x
ADSP-21488DSP SHARC 400MHz
Asynchronous USBXMOS Xcore200 multicore processor
DACESS ES9017K2M
Audio ModesPCM & DSD
Digital and analog inputs
USB Type2.0
Various
Dimensions138 x 69 x 20mm
Housing100% Aluminum
Weight230g
Chargevia USB-A
Accessories1x USB-A cable to AC adapter, 1x micro USB to USB-A cable, 1x micro USB to micro cableUSB OTG, 1x 3.5mm Jack to 3.5mm Jack Cable, 1x Optical to 3.5mm Jack Adapter
Qobuzissime award
Read the test here.
Connections: Inputs
Micro USB1x
USB-A1x
Connection: Output
Jack 3.5mm1x
DACESS ES9017K2M
USB Type2.0
Various
Weight230g
Chargevia USB-A
InputJack 3.5mm
OutputJack 3.5mm
