AUDIO-GD MASTER 1 Pure Class A RCA XLR ACSS Balanced Preamplifier
AUDIO-GD MASTER-1 Balanced Preamplifier Class A RCA XLR ACSS
With this Master-1, Audio-GD offers one of the best preamplifiers in the world, integrating the quintessence of audio technolohy
KEY POINTS:
  • Symmetrical design
  • Class A
  • ACSS RCA XLR
Reference : 6306
1 490,00 €tax incl.
1 241,67 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
AUDIO-GD MASTER-1
Symmetrical Preamplifier / Pure Class A / ACSS RCA XLR
Audio-GD MASTER-1
One of the best preamplifiers in the world ...
Audio-GD presents us once again the quintessence of the audio technology with this MASTER-1, originating in their MASTER series.
This series has enjoyed one of the longest durations of design and testing in the history of the famous brand. The latter will provide you with a totally unmatched musicality in this price range.
High-fidelity interior and connectivity
It has 5 analog inputs: 2x RCA / 2x XLR / ACSS, along with 3 analog outputs also: XLR / RCA / ACSS. The MASTER-1 memorizes all the settings you make, and resumes them correctly when you turn it back on.
Each of the company's products has been scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzers 2700 Series from Audio Precision.
Back Audio-GD MASTER-1
ACSS
ACSS
Audio-GD has its own technology signature called ACSS for "Audio-GD Current System Signal". Thanks to the expertise and know-how of the firm, this technology offers a less colored, more detailed sound, and an unparalleled neutrality.
Ctechnician of the brand is, in addition to being experiencedente, a lover of HiFi and Audio like you and us. That is, when the ACSS output is used, the XLR and RCA outputs go to MUTE.
Remote Control Metal
This HE-9 comes with its metal remote control, brushed aluminum finish. You will find 2 buttons to switch between your different sources, as well as 3 buttons to adjust the volume: Plus / Minus / Mute. The whole class and softening of Audio-GD are visible from this remote, as it is functional and purified.
SNR> 120dB
Frequency Response20Hz - 20kHz (<0.15dB)
Gain (XLR)+ 5dB (70 steps) / + 8dB (99 steps)
Characteristics volumeLinear at 70 steps / exponential at 99 steps
Max Output Level19V (XLR) / 9.5V (RCA) / 4.8mA (ACSS)
Input impedance94KΩ (XLR) / <10Ω (ACSS)
Output Impedance10Ω (XLR) / <10Ω (ACSS)
Channel imbalance<0.05dB
crosstalk> 130dB
Power135W (3 transformers)
Various
Consumption43W (Class A)
WeightAbout 16kg
Housing material100% Aluminum
Dimensions430 x 430 x 93mm
AccessoriesPower cable / Remote control
InputACSS
InputXLR
OutputACSS
ClassClass A / AB
3 reviews
Oui, mais !
Eh bien voilà, j’ai ce pré-ampli qui obtient toujours des louanges dithyrambiques sur les forums, pour le moment j’en suis satisfait, mais hélas, pas totalement !
Il y a comme un manque dans la retranscription de la musique ou tout du moins, dans certaines….
En effet, comme souvent dans les produits chinois, le haut médium/ aigu est très satisfaisant. C’est clair, net, précis, jamais agressif (ouf)très ample, mais en ce qui concerne le bas médium ainsi que les basses, je reste un peu sur ma faim. Mon précèdent pré-ampli à tubes pourtant faisait mieux, ça descendait plus bas, les basses étaient plus abondantes
Moralité, si vous voulez écouter du gros son, ce n’est pas ce matériel qu’il faut choisir…
This review has been posted for AUDIO-GD MASTER 1 Pure Class A RCA XLR ACSS Balanced Preamplifier
Un excellent préampli.
Je ne rédige pas souvent d'avis sur les produits que j'achète. Je fais une exception cependant pour ce préampli. Le rapport prix/performance est simplement imbattable. J'ai eu des préamplis valant trois fois le prix de cet Audio GD et il est largement à la hauteur. Le temps de chauffe est non-négligeable, mais une fois ce temps passé, la performance est au rendez-vous que ce soit sur la dynamique, l'image ou les timbres. Top produit.
Excellent!
Après une petite centaine d'heures d'écoute et d'une partie de ma discothèque, c'est à chaque fois une nouvelle découverte.
La grosse caisse, la caisse claire, les cymbales de la batterie, les percussions de l'orchestre, l'archet des violons, le souffle des artistes, ...., ajoutent à chaque interprétation sa présence et sa complexité.
L'ensemble est d'une clarté, d'une précision, d'une finesse,..., qui autorisent une écoute prolongée dans le plus parfait dépaysement.
Les enregistrements Qobuz, en qualité Master mais déjà en streaming qualité CD, sont aérés et terriblement présents.
Ce préampli Audio-GD Master 1 à trouvé sa place dans l'ensemble suivant:
Lecteur réseau SOTM, Dac Naim, Préampli Audio GD, Ampli Quad 405 (Class A à composants discrets), HP Proac Tablette Reference Height Signature.
Dans un deuxième temps, je prévois de remplacer le Quad 405 par Ampli Audio-GD Master 3 en liaison ACSS avec le préampli.
Dans un troisième temps,..., nous verrons.
 (3)
With this Master-1, Audio-GD offers one of the best preamplifiers in the world, integrating the quintessence of audio technolohy KEY POINTS:...
