FX-AUDIO D802 Digital Amplifier STA326 Class D stereo 2x50W / 8 Ohm Black
FX-AUDIO D802 Digital Amplifier STA326 stereo 2x 80W 4 Ohm
Reference : 10394
109,00 €tax incl.
90,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
The FX-AUDIO D802 is a Class D STA326 amplifier that can be controlled via remote control. As standard, it integrates a 192kHz 24bit digital analog converter associated with an AKM AK4113 S/PDIF interface and a VT1630A VIA Audio/DSP interface.
This amplifier is a "Full Digital" amplifier, i.e. the S/PDIF signal is converted into I2s by the AK4113, then directly amplified by the STA326.
It has three digital inputs (USB, Coxial S/PDIF and Toslink optical).
Its OLED screen displays in real time the source used as well as the sampling rate of the audio file being played. Its USB Audio jack is also OTG compatible. So you can plug in an Android smartphone.
This all-in-one amplifier is also equipped with a digital equalizer with many functions (bass, treble, etc...) adjustable directly from the remote control.
It will prove to be the ideal companion of any digital source.
Its ergonomics and compactness are significant assets to which is added its versatility.
FX-Audio D802 review by Qobuz
" There is no doubt that switching amplification has earned its place in quality Hi-Fi and this FX-Audio D802 model certainly positions itself as a champion in its class by offering sound quality, punch and many adjustment options, all in a minimal footprint and at a very affordable price. "
Test Qobuz
This amplifier emits a slight breath into the speakers during silent passages in the music. Although the phenomenon is very slight, it is still important to take into account when using desktop speakers with close listening.
Characteristics:
  • S/PDIF AKM AK4113 Interface
  • Audio Controller / DSP VIA VT 1630A
  • OLED Display
  • Displaying the sampling rate
  • Amplifier module STA326 : 2 x 80W at 4 Ohm, 2 x 50W at 8 Ohm
  • Nichicon 5400µF x3, WIMA x2 filter capacitors
  • High precision clock
  • Signal to noise ratio (SNR): 100dB
  • Frequency Response: 18Hz - 22kHz
  • Digital equalizer
  • Control by remote control supplied or rotary encoder
  • Inputs: S/PDIF Optical Toslink, Coaxial and USB-B)
  • HP Outputs: On screw terminals supporting 4mm banana plugs
  • 32V 5A power supply supplied (5.5/2.5 jack connector)
  • Dimensions: 190x115x39mm
  • Weight : 700 g
  • USB-A to USB-B cable, remote control and Power supply included
  • Remote control CR2032 batteries not included
  • Direct (or Tone, or HiFi) mode, allows you to override the internal DSP, and amplify the signal live without changes.
Audiophile magazine
Test en français (Cliquez ici).
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipSTA326
Power (W)50.0
20 reviews
Bon ampli FDA - mais
Globalement il fonctionne très bien. Je l'ai utilisé d'abord avec une paire d'enceinte passive (coas tpx musikit). Impec, à la hauteur d'un marantz pm7200 100 fois plus lourd.
Enceinte, j'en ai pris un second et un dsp minidsp pour piloter une paire d'enceinte active....et là ça a été plus compliqué. Un peu de bruit de fond apparent sur tous les HPs et surtout une tenue en puissance très faible. Je soupçonne une sensibilité aux impédances basses (mais HP était des 4 ohm) vu qu'il n'y avait pas de filtres passif, pas de correction de courbe d'impédance. Je vois que ça.
Donc pour utiliser avec une paire d'enceinte passive adaptée à son champ d'application, c'est parfait. Faut faire attention aux utilisations un peu plus exotiques.
This review has been posted for FX-AUDIO D802 Digital Amplifier STA326 Class D stereo 2x50W / 8 Ohm Black
Une révolution
Depuis que je suis passé à la musique dématérialisée, ce petit ampli remplace en mieux mon Vincent SV237, ampli hybride, 25 kgs, d'électronique et de tubes à 2500 Eur... A l'avenir, ça va devenir dur pour les amplis HiFi face à ces merveilles à 100 balles. La révolution est en marche ..., seuls les amplis audiophiles, hors de prix, peuvent encore résister quelques temps à cette nouvelle vague.
Un ampli bourré de qualités.
Tenté par la promotion et les avis lus sur cet ampli, je me félicite de l' avoir acheté. Très belle qualité de fabrication et rendu impeccable, prends peu de place dans l' environnement du PC mais en compagnie d' un Dac U-Sabre TCXO voilà une paire de comparses dont je ne voudrais plus me passer.
Si vous n' êtes pas inconditionnel du bluetooth et si vous n' avez pas la nécessité d' une entrée audio analogique cet ampli est super, je le préfère clairement à mon SMSL AD-18.
Au prix actuel promotionnel de 76,00 Euros, c' est cadeau vu ce qu' il peut donner de plaisir.
Vraiment bluffant
Un peu sceptique au début, malgré les nombreux commentaires élogiants, je me suis vite ravisé.
Cet ampli est vraiment très performant à plusieurs niveaux:
- Très belle finition, qualité au rendez-vous (supporte même des fiches bananes imposantes malgré les tout petits connecteurs).
- Télécommande austère mais pratique, il y a l'essentiel (il faut un peu viser le récepteur mais pas du tout rédhibitoire).
- Les connections numériques essentielles sont présentes et de qualité (l'USB directement reconnu comme carte son).
- L'écran, malgré sa petite taille, est très lisible (merci OLED) et est très joli.
- Vraiment dynamique et puissant surtout vu la taille. On sent vraiment la tenue du grave (toute proportion gardée).
- Testé sur des Boston Acoustic A26 (10-150W, 89 dB) le résultat est très cohérent. Belle dynamique, pas trop analytique mais du détail quand même.
Bref une belle surprise et à ce prix là, on peut se faire un petit système numérique qui consomme rien et qui envoie correctement (à mon avis pas au-delà de 20m²) avec une belle présence, une belle dynamique et du détail.
Par contre je rejoints certains avis du net pour dire qu'il manque un peu de chaleur et d'ampleur de scène.
Comparé à un Linn Majik DSM, on est pas du tout dans la même catégorie! Heureusement.
Je ne dirais pas que c'est plat et sans vie (c'est exagéré) mais on sent que l'ensemble parait un peu "étriqué".
Peut-être que quelques heures de rôdage vont remédier à ces quelques lacunes... mais on atteint pas des résultats mieux que des appareils 10x + chers ou alors ils sont très mal exploités!
En tout cas c'est chouette de voir l'évolution quand on compare à un vieil ampli analogique de + de 15 kgs et c'est une petite machine très sympa.
à essayer pour ceux qui seraient encore sceptiques.
soignez vos câbles (et enceintes)...
A la lecture des forums et autres "avis" concernant les amplificateurs FDA (quelle que soit leur marque), je ne suis pas étonné par d'assez nombreuses critiques ou déceptions. Et, sans orgueil de ma part, je crois avoir mis le doigt sur l'origine de ces frustrations. Je m'explique: tout système HIFI est limité par l'un au moins de ses maillons: cela peut être les haut-parleurs ou/et les câbles. En effet, pour l'avoir expérimenté, je ne constate aucune amélioration sonore entre mon ampli analogique et mon FDA lorsque j'utilise, par exemple, un câble numérique coaxial Qed! par contre en le substituant par un câble num coax Canare, j'entre dans un autre monde qui permet alors à mon FX audio D820 d'exprimer toutes ses qualités. On ne le dira jamais assez, un système musical est constitué de plusieurs maillons et le résultat final est toujours limité par le maillon le plus faible, d'où ces frustrations et déceptions. Alors ... soignez vos câbles numériques, vos câbles d'enceinte et vos haut-parleurs et votre avis changera ... très probablement.
