- Full Digital Amplifier Bluetooth 2x50W -
This amplification module incorporates a chip TDA7492, ensuring a power of 2x50W. The design of the Class D amplifier makes it a high-performance solution. Equipped with a Bluetooth chip, it will also allow you to stream your music from your sofa.
The amplification chip TDA7492 provides efficient amplification at a very low price. With a THD of 10% with a VDC of 25V and an impedance of 6 Ohms, a 90% efficiency, a frequency response of 20Hz - 20kHz, a noise reduction system and short circuit protection as well as excessive temperatures, it turns out to be ideal for mounting small audio systems. In addition, the commutateur DIP Switch allows you to select the output gain to suit any situation.
Equipped with a Bluetooth chip CS8635, the module will allow you to directly stream your audio files remotely.
