CANARE BCJ-JRU High performance BNC inlet / Panel mount 75 Ohm
CANARE BCJ-JRU High performance 75 Ohm BNC inlet
Reference : 10462
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
This BNC 75 Ohm base developed in Japan by CANARE ensures a high quality signal.
It has a central pin made of copper Beryllium machined in the mass and plated Gold with a high precision.
Its notoriety is no longer to be done and the connectors of the firm, initially intended for the professional market, did not take long to break into the Hi-Fi market.
Features:/ Strong>
  • BNC female connector
  • Material: metal
  • Impedance: 75 Ohm
  • Central Pin Copper Beryllium Gold plated
  • Does not require welding
  • Insulation: PTFE
  • Dimensions: 30x25x23mm
  • Diameter of drilling: 20mm
  • Internal diameter: 16mm
  • Spacing: 29mm
  • Weight: 18g
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)N/A
Impedance (Ω)75
Contacts Material (Connector)Beryllium Copper
Internal widthN/A
Internal depthN/A
Internal heightN/A
