AUDIOPHONICS T-amp TA2020 Amplifier Case Aluminum Black 2x 7W / 8 Ohm
Audiophonics T-amp TA2020 2x20W Boitier Aluminium Noir
4.8 / 5
Reference : 8573
59,00 €tax incl.
49,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Based on an architecture Tripath in T-Classwith a TA2020 chip, this T-amp will enchant you with its precise and dynamic sound, despite its low maximum power of about 2x20W.
Compact and stylish it is as effective for sounding office audio systems as Bookshelfs in a small volume.
It is more than enough for moderate volume listening, even on low-output 88dB speakers.
Warning, this amplifier may be sensitive to interference from radio equipment such as tuners./ P>
Features:/ Strong>
  • 1 x RCA Stereo Plated Gold Input
  • HP output via gold-plated and insulated terminals
  • Aluminum Case
  • Blue LEDs operating.
  • HP on / off delay to prevent interference
  • Volume control potentiometer
  • Overall dimensions: 146.5 x 97 x 37mm
  • Power @ 1kHz @ 0.1% THD:
    - 7W under 8ohm
    - 11W under 4ohm
It is providedwithout power supply.
To power it you can use any 12V power adapter that can supply a minimum current of 1A.
We recommend a linear model for better quality Audio:href = "https://www.audiophonics.fr/fr/alimentations-hi-fi/audiophonics-alimentation-lineaire-regulee-filtre-emi-rfi-12v-2a-25va-p-11375.html" target = " _blank ">Regulated Linear Power RF EMI FilterI 12V 2A 25VA.
The center pin of the power connector will be + 12V.
https://www.audiophonics.fr/images2/8573/8573_audiophonics_ta2022_t-amp_3.jpg
https://www.audiophonics.fr/images2/8573/8573_audiophonics_ta2022_t-amp_1.jpg
5 reviews
Super rapport qualité/prix
Étonné de voir ce que ce minuscule ampli peut donner avec des Yamaha NX-E400, la scène sonore est large, détaillé, les graves sont bien tenues, c'est très agréable à l'écoute.
J'ai mis une alimention 12V délivrant 6A pour être tranquille.
Pour les connaisseurs il s'agit d'un FX Audio FX-202A et je crois bien qu'Audiophonics est le seul vendeur en France à le vendre.
Je le recommande vraiment pour ce monter un système compact et ultra efficace.
This review has been posted for AUDIOPHONICS T-amp TA2020 Amplifier Case Aluminum Black 2x 7W / 8 Ohm
Nettement mieux que mon ancien lepai ta-2020
Plus petit, plus léger, plus sobre et avec des composants et connectiques de bonne qualité. Je recherchais le meilleur ampli à base du ta2020 pour une paire d' Infinity Beta-20 dans un bureau de 11m² et j'en suis satisfait il "paraît" plus puissant pourtant j'ai réutiliser l'alimentation 13.5v-3.0A, maintenant j'espère qu'il dureras plus longtemps que le lepai qui m'a lâché au bout de 4ans. ^^
rapport qualité / prix
Je possédais une ancienne version qui n'avait pas d'anti plop. Du coup, j'ai fini par acheter cette version qui dispose d'une temporisation. Sans regret car ce modèle est également nettement plus puissant. Mon impression en termes de rendu est qu'il me semble difficile de faire mieux à ce niveau de prix.
Très bien !
Résultat surprenant en dépannage sur des JBL pro 38cm et compressions... Puissance déjà confortable, souffle inaudible. Pas d'échauffement perceptible.
Ordi portable et petit DAC AIM ultimate à l'entrée.
Je voulais aussi essayer une alim à découpage Meanwell,50w et 12v sur cet ampli. Résultat satisfaisant, bruit de fond presque inaudible, Très au large question puissance pour un encombrement minimum.
Par contre, les prises
Fiche d'alimentation Jack DC Ø 5.5 - 2.5mm , c'est pas le top....
petit qu'en a pas l'air...
bjr,je me suis offert ce petit ampli pour mettre dans mon coin atelier en sous sol,et j'avoue que je suis bluffé.malgré sa petite puissance théorique,il a une clarté et une dynamique impressionnantes.une petite dureté en aigu,,mais elle s'attenue après un moment.l'alime prevue(8543) LT1083, n'était plus disponible,alors j'en ai fait une,avec tous les éléments de kit permettant de la faire,ci,transfo R core,boitier,entretoises,visserie,interM/A prise secteur,fusible 5x20,prise alime plus jack dc tout dispo.l'alime en kit ne m'a pas couter plus cher que l'alime de base prevue,seulement la peine,et le plaisir de le faire.n'hesitez pas le resultat en vaux la peine.
