MiniDSP PWR-16 16 channels ICEpower Class D Amplifier 400W
MiniDSP PWR-16 16 channels IcePower Amplifier 400W
By buying this product you get 159 loyalty points
Reference : 10519
1 590,00 €tax incl.
1 325,00 € tax excl.
Shipping from France
Billing in France
Technical support in France
The miniDSP PWR-16 is an ultra-compact and highly efficient amplifier up to 400 Watt for multi-zone custom installations.
This amplifier is one of the lightest and most compact in its class and excels with its impressive size power ratio and incredible efficiency.
The PWR-16 has 16 clasped D-channel channels via ICEpower® in eight zones.
Each channel can deliver up to 80W of power at 4 ohm.
The two channels per zone can be switched in mono (BTL: bridge-tied load) to deliver up to 160W of power under 8 ohm.
The result: an extremely efficient and flexible amplifier can be used in many configurations.
A complete set of control and protection functions make this amplifier an extremely gifted and robust device.
It features a remote control, automatic signal detection, and individual zone deactivation to ensure minimal energy consumption.
Broad outlines :
  • Powered in Class D by an ICEpower® for max. of 400W
  • 16 channels in 8 zones with each "bridgeable"
  • Analog Inputs RCA
  • Full Area Controls by GPIO
Features:/ Strong>
  • Number of channels: 16 unbalanced channels, 8 channels in BTL mode, or asymmetrical / BTL combination
  • Poweroutput: 400 W
  • Continuous output power: 80 W per channel at 4 ohm, unbalanced (up to 5 channels)
  • THD + N: 0.003%, 4Ω, f = 100Hz, Po = 1W
  • Dynamic range: 110dB (SE), 115dB (BTL)
  • Frequency response: ± 0.4 dB, 10Hz - 20kHz
  • Input sensitivity: 0.92VRMS (80W, SE mode, 160W, BTL mode)
  • Input impedance: 47 kΩ
  • Certifications: FCC / CE / IEC / PES / C-TICK
  • Power supply: 85-264V AC, 45-65 Hz (mains cable supplied)
  • Fuse: 6.3A
  • Dimensions (H x W x D): 44 x 424 x 314 mm
  • Weight: 3.5 kg
OutputSpeaker terminal
Channel16
Amplifier chipIce Power
Power (W)400.0
