TOPPING TP60 Stereo Amplifier Tripath TA2022 Class T 2x50W 8 Ohm
TOPPING TP60 Amplificateur
4.0 / 5
Reference : 10101
179,00 €tax incl.
149,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
The TOPPING TP60 delivers up to 2x 80W under 4 Ohm, a power that, although limited in appearance, is particularly surprising.
Baon a Class T circuit, this TRIPATH TA2022 amplifier is equipped with quality components (Nichicon capacitors, EPCOS, TAKAMISAWA relay, ALPS potentiometer, etc ...).
Subtile combination of clarity and great musicality, this generous amplifier has nothing to envy the more powerful amplifiers in its class.
Warning, this amplifier may be sensitive to radio interference from FM radios and tuners./ P>
Features:/ Strong>
  • Amplifier TRIPATH TA2022
  • Architecture Class T
  • Volume control via ALPS potentiometer
  • Gain: 27.3dB
  • Stereo line input on unbalanced RCA sockets x2
  • 24k Gold Plated RCA Headers
  • Outputs on 24k gold-plated terminals for high-section cables and banana plugs
  • Output Power by Channel: Stereo 2 x 50W under 8Ω (10% THD + N), Stereo 2 x 80W at 4Ω (10% THD + N)
  • "Audiophile" power:Stereo 2x 40W under 8Ω (0.01% THD + N), Stereo 2x 40W under 4Ω (0.01% THD + N)
  • THD + N: 0.0085% (1 kHz)
  • Frequency Response: 20Hz - 20kHz (1dB)
  • Signal Noise Ratio: 90dB
  • Line Input Sensitivity: 860mV rms
  • Supplied power cable
  • Dimensions: 327x174x65mm
  • Weight : 5kg
[Img-11867-left-thickbox_default]
[Img-11868-left-thickbox_default]
[Img-11869-left-thickbox_default]
[Img-11870-left-thickbox_default]
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTA2022
Power (W)50.0
2 reviews
Topping
Excellent RQP, bien construit, doux, suffisamment transparent, timbres respectés, à utiliser sur des HP à rendement correct, vaut 4 fois son prix de vente.
This review has been posted for TOPPING TP60 Stereo Amplifier Tripath TA2022 Class T 2x50W 8 Ohm
Presque parfait
Cet amplificateur est capable de faire des merveilles. Associé à un dac FX01 on obtient pour à peine plus de 200€ un ensemble bourré de qualités, capable de driver des 38cm.
Il surpasse très largement le FX D802, IAMD V200, beaucoup plus de délicatesse dans le rendu, plus nuancé, moins brut et aucunement simplifiant.
Il surpasse également un SMSL SA-S3 (ta2021b, un incontournable également malgré ses limitations)
Ainsi qu'un ancien modèle de sono et un Marantz PM5005 (ces 2 là simplifient et masquent beaucoup de détails en comparaison du topping) même si le marantz est agréable et montre de sérieuses qualités si bien associé le Topping a clairement ma préférence.
Je l'ai également comparé à un petit class D icepower de 50w, et là aussi le TA2022 s'impose.
Les points négatifs qui lui font perdre une étoile: pas de télécommande, des transfos qui ronronnent un peu quand on est à moins de 50cm de l'ampli ça peut peut-être se révéler gênant pour une écoute de proximité de type homestudio. A noter que mon environnement sonore est très silencieux (campagne lojn de toute route fréquentée)
Globalement je trouve ce produit très satisfaisant et je regrette simplement de ne pas l'avoir testé plus tôt. Privilégiant des produits plus récents en class D ou FDA qui ne m'ont finalement rien apporté et se sont révélés franchement décevant. Clairement un TA2022 bien mis en oeuvre comme c'est le cas ici est toujours excellent en 2018.
A souligner la très belle qualité de fabrication, borniers de bonne taille, boitier bien fini, réglage du volume fluide, rien ne fait cheap.
En conclusion le TP60 c'est un savant mélange entre douceur et précision, punch et délicatesse.
 (5)
