AIM Ibullet USB Audio Interface for Microphone / Headset 4-pole
AIM Ibullet Interface Audio USB pour Micro/Casque 4 pôles
Reference : 7063
13,50 €tax incl.
11,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
AIM Ibullet USB Audio Interface for Microphone / Headset Smartphone 4-pole
This USB design interface allows you to use your headphones for Smartphones equipped with microphones and 4-pole Jack connectors on any PC or Mac.
Why will you say?
The advantage of such a product is to make it possible to connect your smartphone microphone to your PC / Mac.
So your headset sold with your smartphone can also be used as a headset for your PC or Mac.
It also improves the signal-to-noise ratio at input and output compared to the original components of these devices.
Characteristics :
  • Patented technology and design
  • Converter: Cmedia HS100
  • Connector: 3.5 mm 4-pin plug
  • Compliance: USB 2.0 full speed, Plug & Play, compatible with USB 1.0
  • Headphone Output: 16-bit, 44 KHz / 48 KHz, SNR 93dB
  • Input Micro 16-bit, 44 KHz / 48 KHz, SNR 83dB
  • LED: blue indicating the status
  • Dimensions: 39.6 x 22.1 x 12.3mm
  • Weight: 6g
  • Interface: USB type A male
  • PC and MAC compatible: Plug & Play
  • PS: Not suitable for Nokia and Sony phones
https://www.audiophonics.fr/images2/7063/7063_aim_ibullet_headphone_3.jpg
"> Only availablein white
https://www.audiophonics.fr/images2/7063/7063_aim_ibullet_headphone_4.jpg
https://www.audiophonics.fr/images2/7063/7063_aim_ibullet_headphone_2.jpg
https://www.audiophonics.fr/images2/7063/7063_aim_ibullet_headphone_1.jpg
https://www.audiophonics.fr/images2/7063/7063_AIM_IBULLET_3.jpg
Fatal : tu doutes ! Erreur.
Utilisé en interface entre sortie PC USB et casque JBL J88i (HP de 50mm). Ce n'est pas le même changement de qualité que celui ressenti en passant d'un ampli bas de gamme à du haut de gammes, certes. MAIS l'apport est sensible le son est plus clair, plus net. Et quand tu es dans un TGV : tout ce qui peut bonifier est à prendre :).
This review has been posted for AIM Ibullet USB Audio Interface for Microphone / Headset 4-pole
