AUDIO-GD MASTER 11 Preamp / Headphone Amp / Balanced DAC 4xPCM1704UK & DSP
Reference : 10082
1 999,00 €tax incl.
1 665,84 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
AUDIO-GD MASTER 11
DAC Symmetry / Headphone Preamplifier / Amplifier
Power and versatility side by side ...
Audio-GD presents us this time a symmetrical DAC ultra efficient all in one, associated with a preamplifier and amplifier headphone. The MASTER 11 is a perfect fusion of MASTER 7 and MASTER 9. It is thus logically destined to become a cult DAC in the history of Mr. He Qinghua's firm.Even if Audio-GD had already given their nobility to MASTER 7 and 9, the best engineers of the brand offer here a 3-in-1 DAC in its most accomplished form with outstanding performances.
An interior and connectivity particularly provided
This MASTER 11 is designed around 4 PCM1704UK converters and an Altera Cyclone DSP working in parallel, as well as a discrete Class-A ACSS circuit without any PDO with separate power supply. It has 6 digital inputs: BNC / RCA / Toslink / I2S optics via HDMI / USB-B (AMANERO), as well as 3 analog inputs for preamplification: XLR and 2x RCA. The DAC and preamp outputs are in RCA and XLR, and the headphone output stage consists of an XLR 4 PIN, two XLR 3 PIN, and a 6.35mm jack output. TheThe result is a great musicality thanks to an exceptional dynamic and an extremely rich rich sound.
A worked and pointed architecture
PCM1704UK / I2S / USB AMANERO / TCXO
The MASTER 11 is equipped with no less than 3 R-Core transformers (195W total), NOVER capacitors (50000uF in total), and the famous Dale resistors. Separate regulators chargeto develop one of the best signal-to-noise ratio for a DAC in this category. A TCXO high precision clock is present in this MASTER 11 in order to significantly lower the Jitter. Each Audio-GD product is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzers 2700 Series.
DSP - Altera Cyclone
The French definition of DSP would call it "Digital Signal Process", or "Digital Signal Processing". This mini processor is optimized to process a large amount of data in parallel with each clock cycle. It is very efficient to process the digital signals that arrive to it. The Altera Cyclone in this Audio-GD MASTER 11 makes it a very high fidelity product.
4x PCM1704UK
These four analog digital converters (DAC) make use of the R2R conversion which consists in directly using the bits of the digital signals to reconstruct the analog signals, all this acting on a network consisting solely of resistors having a given value (R) and its double (2R), without going through an over-sampling phase.
Features:/ Div>
Ratio Signal Noise:> 120dB Gain: + 16dB (XLR)
Digital volume control: 100 steps (Exponential)
Crosstalk:> 130dB
Frequency response: 20Hz - 20kHz (at -0.1dB) / 1Hz - 140kHz (at -3dB)
Output level max. : DAC (5V) / Preamp (10V) / Headphone amplifier (19V) ACSS Output Level: 1.2mA + 1.2mAOutput Impedance DAC / Headphone Amplifier: 1 Ohm Input Sensitivity: 0.5Vp-p (Coaxial, 75 Ohm) / 19dBm (Optical)
Headphone Output Power: 16000mW (25 Ohm) / 8000mW (50 Ohm) / 4000mW (100 Ohm) / 1300mW (300 Ohm) / 650mW
Supported sampling rates: USB and I2S (44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz) / BNC (44.1kHz, 48kHz, 88.2kHz, ) / Optical (44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz)
Power Consumption: 45WDimensions: 430x430x93mmChassis 100% aluminum, black anodized Weight: 15kgIncluded accessories: Power cord / USB cable / Aluminum remote control
Cet appareil est une réussite marquante
Sur le papier, ce combo DAC/préampli/ampli-casque imposant, réalisé ‘à l’ancienne’ présente des caractéristiques de premier ordre : circuits symétriques en éléments discrets et de classe A, alimentation surdimensionnée, la meilleure puce DAC du marché (R2R, le top pour le format PCM), une des meilleures cartes pour la connexion USB avec un ordinateur…
Il se révèle à la hauteur de ce qu’on peut en attendre. Ses qualités de précision, de clarté, de justesse tonale contribuent à une lisibilité musicale du plus haut niveau. Le relief de la scène sonore est impressionnant. Les instruments ou les voix apparaissent parfaitement séparés dans l’espace, avec des timbres de toute beauté. Le son s’entend très précis tout en étant d’une douceur remarquable. La partie ampli-casque est aussi exceptionnelle.
Le rapport qualité/prix est époustouflant. Il est très supérieur à un combo DAC/ampli-casque que je possède et ayant reçu toutes les distinctions à travers le monde (diapason d’or, choc classica, what-hifi, best audio…) et pourtant de même niveau de prix. Il est aussi plus à mon goût qu’un DAC très réputé (dont je ne citerai pas la marque, mais que les audiophiles reconnaîtront si je dis qu’il est italien ;) ) qui vaut 2 fois plus cher, alors même qu’il ne fait que DAC et ni préampli, ni ampli-casque.
Je ne l’ai pas comparé en parallèle, mais je crois qu’il n’atteint pas quand même le niveau de naturel des meilleurs DAC… dont le prix est 5 à 10 fois celui de ce Master 11. Il en est cependant vraiment très proche. C’est un appareil d’une musicalité exceptionnelle, qu’il doit à son DAC, mais je pense aussi à ces circuits d’amplification analogique.
Conquis par ce Master-11, je me suis dit qu’audio-GD, connue surtout pour ses DACs, maîtrisait très bien les amplis et j’ai décidé d’acheter et tester le Master-2H. Je laisse un commentaire sur cet ampli dans la section consacrée. En un mot, cet ampli est un triomphe.
J’ai cependant une réserve. Le premier Master-11 que j’ai reçu était multi-défectueux, avec des problèmes de ronflettes et de télécommande. Cela m’a permis de vérifier les qualités du SAV d’Audiophonics, qui a été au rendez-vous. Je les en remercie. Cependant, il m’a fallu attendre plusieurs mois pour obtenir un appareil en échange standard. A méditer si vous êtes impatients. Cependant, cela vaut vraiment le coup d’attendre.
Ce master-11 est très très vivement recommandé !
 (4)
This review has been posted for AUDIO-GD MASTER 11 Preamp / Headphone Amp / Balanced DAC 4xPCM1704UK & DSP
