AUDIO-GD MASTER 7 2016 Balanced DAC 8x PCM1704UK / DSP I2S 24bit/192kHz
AUDIO-GD MASTER 7 2015 Balanced DAC 8x PCM1704UK / DSP I2S 24bit/192kHz
Reference : 10514
2 299,00 €tax incl.
1 915,84 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
AUDIO-GD MASTER 7
DAC Symmetry / 8x PCM1704UK / DSP I2S HDMI
A DAC DSP out of the ordinary ...
The latest addition to the PCM1704UK brand converters, it is a new iteration that we consider it the most successful DAC on this component: indeed it does not contain less than 8!All the components are sorted on the shutter and paired by hand: this is a question of very high fidelity, so expect a breathtaking sound experience. To top it all, this DAC also won a Qobuzissime from Qobuz: Qobuzissime for this DAC with superlative and super sound!
Specially provided interior
Built-in PCM1704UK converters allow you to manage sources up to 24Bit / 192kHz. The MASTER 7 has 6 inputs: BNC SPDIF, AES / EBU, Coaxial SPDIF, Toslink Optics, and I2S via HDMI or RJ45, as well as 3 outputs: RCA, ACSS, and XLR. That is, the entire internal wiring is designed in OCC Copper, and a TCXO Audio-GD Clock is directly integrated, allowing the Jitter to significantly decrease.
An exceptional architecture
24bit / 192kHz / I2S /TCXO / HDMI
Its architecture with built-in DPS is combined with a separate oversized power supply of 21 groups, including 19 in Class A high-flying. Its transformers develop up to 1500W of power, for only 48W of consumption. The MASTER 7 est so designed around 8 PCM1704UK and DSP1 (Altera Cyclone II) that work in parallel, alongside ultra discrete AOP. A structure 100% aluminum black anodized finishes this architecture sober, elegant, which reveals all its power.
DSP - Altera Cyclone II
The French definition of DSP would call it "Digital Signal Process", or "Digital Signal Processing". This mini processor is optimized to process a large amount of data in parallel with each clock cycle. It is very efficient to process the digital signals that arrive to it.
8x PCM1704UK
These 8 analog digital converters (DAC) use the R2R conversion which consists in directly using the bits of the digital signals to reconstruct the analog signals, all this acting on a network constituted solely by resistors having a given value (R) and its double (2R), without going through an over-sampling phase.
Characteristics :
Ratio Signal Noise:> 120dB
Output Impedance: 10 Ohm </ Div>
Output Level: 2.5V (RCA) / 5V (XLR) / 2 + 2mA (ACSS)
Input Sensitivity: 0.5Vp-p (75 Ohm, Coaxial) / 19dBm (Optical)
Supported operating systems: Windows (44.1kHz to 192kHz) / OSX (44.1Khz to 384kHz) / Linux (44.1kHz to 192kHz)
Rate of exchange(44.1kHz, 48kHz, 48kHz, 88kHz, 96kHz, 192kHz) / BNC (44.1kHz, 48kHz, 88.2kHz, 96kHz) / Coaxial Optical (44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz)
(44.1kHz, 48kHz, 88.2kHz, 96kHz) / Optical (44.1kHz, 48kHz, 88.2kHz, 96kHz) / Coaxial (44.1kHz, 48kHz,
Power Consumption: 48WDimensions: 430x430x93mmChassis 100% aluminum, black anodized Weight: 15kgIncluded Accessories: Power cord
Excellentissime !
Scène très détaillée, basses profondes, tout simplement magnifique ! En utilisant des sources de qualité(flac, sacd...) le rendu est majestueux ! Une tuerie, vraiment !!! Le boitier du dac est très imposant et de très bonne finition, il respire le sérieux ! Merci Kingwa aka Audio GD :-)
This review has been posted for AUDIO-GD MASTER 7 2016 Balanced DAC 8x PCM1704UK / DSP I2S 24bit/192kHz
