AUDIOPHONICS M2 DAC USB PCM2704 TPA152 Headphone Amplifier 16bit / 48khz
Audiophonics M2 DAC USB PCM2704 TPA152 16bit/48khz
Reference : 9035
23,90 €tax incl.
19,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
This product with the case of the small M1 integrates a DAC as well as a small headphone amplifier. It is ideal for enjoying good audio in the office, roaming from a laptop etc ...
Equipped with a mini USB input, stereo output jack 3.5 and a potentiometer allowing you to control the volume it is a complete and autonomous product.
Small, practical and aesthetic in its metal shell it proves valuable in many audio usage scenarios.
Features:/ Strong>
  • Compatible with all systems without drivers
  • Dynamic range: 100dB
  • Sampling rates: 16bit 32.44.1 and 48khz
  • Noise Ratio: 100dB
  • THD + N: 0.002%
  • ASIO Support
  • Compatible with headphones: 16 to 150 Ohm
  • Input: Mini USB
  • Output: 3.5mm Stereo Jack
  • Dimensions: 50 x 40 mm
  • Weight: 160g
Bon produit
Fonctionne bien sur mon iMac.
Connexion facile, prend peu de place sur le bureau et le réglage du volume est très pratique. Connecter sur mon QINPU Q2 et une paire de KLIPCH R-14M voila une petite chaine de bonne qualité pour 300€.
This review has been posted for AUDIOPHONICS M2 DAC USB PCM2704 TPA152 Headphone Amplifier 16bit / 48khz
