AUDIOPHONICS U-SABRE ES9018 DAC DSD Amplifier TDA Class D 2x 170W / 4 Ohm
Reference : 9988
690,00 €tax incl.
575,00 € tax excl.
Shipping from France
Billing in France
Technical support in France
Here is the complete assembled and tested version in our workshops of our latest U-Sabre family converter coupled to a Class D TDA8950SMPS Amplifier delivering 2x 170W 4 Ohm.
With the best in each domain, you can easily and cost-effectively deliver exceptional conversion quality and support all sampling rates and the DSD.
Equipped with three digital inputs, a selection of sources and a volume control it will quickly become the absolute reference in this price range.
Features:/ Strong>
  • White Oled Display
  • Integrated power supply
  • Torema encapsulated toroidal transformer Talema (Ireland) ultra low noise and very low radiation
  • USB Isolation
  • Interface USB XMOS (Risc 6 cores) Asynchronous (Asio, Wasapi, etc ...)
  • Natively recognized on Mac OS and Linux without drivers
  • Inputs: 1x Optical, 1x Coaxial SPDIF and 1x USB-B (the interface here is the same as in our U-Xmos 192 and 384kHz)
  • Decoding up to 32bit 384kHz (USB-B) by Sabre ES9018 (THD + N: -120dB, DNR: 127dB)
  • DSD native support (DSD64 (dop / native), DSD128 (dop / native), DSD256 (native))
  • FDO output stage (full differential output)
  • AOP high fidelity low noise: 6x JRC 5534 (Japan Radio Co ltd) including two on DIP8 support (to be changed at leisure)
  • Settings: Phase +/-, Rolloff fast / slow, DSD IIR bandwith 47k / 50k / 60k / 70k
  • Analog outputs on RCA and XLR
  • Amplifier TDA8950SMPS Class D 2x 170W
  • Outputs isolated terminal blocks accepting banana plugs and forks
  • Selecting sources by pushbutton
  • Volume control via push-button (+/-)
  • Housing 100% Aluminum
  • Rubber feet
  • Dimensions of the case: 350x240x90 mm
  • Weight: 3.5kg
  • Remote control 100% Aluminum supplied
  • Power cord included
[Img-17246-left-thickbox_default]
[Img-15269-left-thickbox_default]
[Img-13912-left-thickbox_default]
[Img-11365-left-thickbox_default]
