GUSTARD X20 XMOS Symmetrical Out ES9018X2 XMOS USB AES/EBU 32bit 384Khz
Gustard X20 XMOS Symmetrical Out ES9018X2 XMOS USB AES/EBU 32bit 384Khz
By buying this product you get 109 loyalty points
Reference : 11004
1 090,00 €tax incl.
908,33 € tax excl.
Shipping from France
Billing in France
Technical support in France
The DAC ConverterGustard X20 XMOS double ES9018 SABERis designed according to the rules of the art. This DAC 32bit 384Khz has a USB 2.0 class of very high level. With an accuracy of 0.1PPM and a power of 500MIPS with processor CPLD Altera MAX II,the DAC X20 offers a high resolution, a very low jitter, an output entirely in discrete symmetrical transistors in class A.
The quality of its components (clock ESS ES9018 TCXO 100MHZ), its processorAltera MAX IICPLDwith 8MB of built-in memory predestines its use on high-end Hi-Fi systems. Of course, this DAC with its asynchronous USB inputs with three separate clocks decodes the DSD 64, 128, DXD 32bit 384Khz being fully ASIO bit perfect under Windows (requires a driver supplied on mini CD).
An advanced clock system:
The DAC Gustard X20 offers a classic asynchronous digital mode as well as a Automatic Adaptive Technology Master Clockautomatically deriving on the correct TCXO clock frequency under the best conditions (A clock dedicated by multiple frequency).
An analog stage in discrete transistors with gain selection:
The analog output stage of this DAC Gustard X20 in Class A offers three front selectable gain stages: 0dB, 6dB and 12dB. So with the volumedigital 64bit ESS without loss of dynamic, one can directly attack by the balanced XLR outputs where unbalanced RCA, a stereo power amplifier.
A separate digital and analogue power supply:
Its linear power supply with dual toroidal transformers (one for digital, one for analog) shielded provides a very low noise level preventing jitter by electrical pollution. The control section offers ROVER capacitors with high filtering capacity, LM2941 and discrete transistor based regulators.
HDMI / I2S compatibility :
The entry HDMI to I2S formatDAC Gustard X20 XMOS is compatible with Audio GD format. (See the diagram at the bottom of the description.)
General technical characteristics:
  • TCXO full size clock 100Mhz (ES9018) (0.1PPM).
  • Altera MAX II CPLD processor.
  • Real outputs in Symmetrical schema on XLR.
  • Analog gain stage 0dB, 6dB, 12dB.
  • Digital volume ESS SABER 64bit non-destructive in steps of 1dB.
  • Selectable DSD filter 50, 60 or 70khz.
  • Sharp PCM filter and Slow Roll OFF.
  • Phase reversal 0 °, 180 ° by the display.
Digital Inputs:
  • One input USB Audio class 2.0 32bit 384Khz DSD 64 and 128 DOP128, DSD512.
  • An I2S input on HDMI (see wiring diagram) 32bit 384 KHz and DSD 64, 128, 256, 512.
  • A standard input IEC60958 AES EBU 110Ohm gold plated pins 24bit 192Khz (compatible with DOP64).
  • a standard input IEC60958 BNC SPDIF 75 Ohm plated Gold insulation PTFE (compatible DOP64).
  • A coaxial input to standard IEC60958 PTFE insulation 75Ohm Plated Gold 24bit 192Khz (compatible with DOP64).
  • A Toslink optical input to the IEC60958 24bit 96Khz standard (DOP64 compatible).
Analog Outputs:
  • An analog balanced stereo output gold-plated pins.
  • An analog stereo output on Cinch RCA CMC plated Gold PTFE insulation.
The bundle contains:
  • An IEC power cord of 1m75.
  • A mini CD containing the XMOS drivers.
Dimensions and weight:
  • 385x280x150mm.
  • Weight with packaging 4Kg.
ITS / HDMI Schema of Gustard Audio Products.
[Img-17221-left-thickbox_default]
[Img-17253-left-thickbox_default]
[Img-17242-left-thickbox_default]
[Img-17237-left-thickbox_default]
