Little Dot declines its DAC_1 in a more ergonomic version, with headphone amplifier and integrated volume control.
The headphone output is amplified by a pair of discrete transistors BD139 / BD140 driven by a chip LME49710.
The conversion section uses the best available chips as well as a 2 quartz clock circuit to ensure an output signal without jitter.
Characteristics :
- High performance conversion chip WOLFSON WM8740
- Receiver chip WM8805 ultra low jitter (50ps)
- Able to process signals up to 24Bits / 192KHz (except USB)
- Digital over- sampling filter 64fs (> 100kHz) / 128fs (<100kHz) configurable on 2 positions (Soft & Sharp) or totally disengageable
- Operational base amplifiers for upgrade or upgrade
- SPDIF digital input on Toslink, BNC & RCA
- USB DATA input
- Analog outputs on RCA jacks
- Transistor Headphone Amplifier
- Volume adjustment
- Device supplied with a 75Ω BNC coaxial cable, and an IEC 230V power cord, a USB cable
Technical specifications:
- Frequesampling rates: 8kHz to 192kHz
- Quantification: 16 to 24 Bits
- Digital Audio Inputs: SPDIF to BNC 75Ω Jacks, Coaxial (RCA 75Ω), Optical (Toslink) & USB Input
- Level of Inputs BNC & RCA: 500mV (RMS)
- Analog Audio Output: Asymmetrical to RCA Jacks
- Output Level RCA Unbalanced: 2V Per Channel (RMS)
- Frequency response: 20Hz to 20KHz (+/- 1db)
- Signal to Noise Ratio: 110dB
- Dynamic Range: 117dB
- Harmonic Distortion: -104dB
- Power Consumption: 10VA
- Protection Fuse: 1A
- Dimensions: 365 x 217 x 61 mm (L x W x H)
- Weight : 2kg
- 1 year warranty AUDIOPHONICS
[Img-12423-left-thickbox_default]
[Img-12424-left-thickbox_default]
[Img-12425-left-thickbox_default]
