POPPULSE DAC DSD/DXD 2x ES-9018 32bits/384kHz TCXO
4.7 / 5
By buying this product you get 82 loyalty points
Reference : 9096
829,00 €tax incl.
690,84 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
Audiophonics is proud to present the latest and flagship of the brand POPPULSE .
The latter, with what is best in each area allows you to have a high quality conversion.
It supports all sampling rates and DSD.
Equipped with four digital inputs, a selection of sources as well as a volume control , will soon make it as a reference in medium and high quality converters.
Features :
  • White OLED display
  • Integrated linear power supply with EMI filter
  • Dac : 2 X Sabre ES9018
  • 2 shielded toroidal transformers ultra low noise and very low radiation
  • Asynchronous USB interface AMANERO high quality
  • Recognized natively in Mac os and Linux without drivers
  • Bitperfect : WASAPI / ASIO for Microsoft XP Win8
  • Inputs: 1x Optical , 1x Coaxial , 1x USB and one AES / EBU
  • Decoding up to 32bit / 384kHz (USB) by two ES9018 Sabre (THD + N: -120dB , 127 dB DNR )
  • Native support for DSD ( DSD64 ( dop / native ) DSD128 ( dop / native ) DSD256 (native)
  • Filters: Rolloff fast / slow , DSD IIR bandwith 47k / 50k / 60k / 70k
  • Analog outputs on RCA and XLR
  • Source selection by push button
  • Volume control with push button (+/-)
  • Black Aluminium Facade
  • Rubber feet
  • Case dimensions: 430 x 270 x 65 mm
  • Weight : 4570 kg
3 reviews
DAC POPPULSE ES 9018
Très bon appareil qui sonne parfaitement. Possibilité de moduler le gain et le dac ce qui est très utile et efficace. A conseiller.
This review has been posted for POPPULSE DAC DSD/DXD 2x ES-9018 32bits/384kHz TCXO
Excellent produit
Excellent DAC, extrêment détaillé et tout en finesse et très dynamique. Descent très bas, aigus aériens! Necessite cependant un bon rôdage avant de pouvoir s'exprimer pleinement. J'avais peur de l'associer à mon ampli PopPulse T180 classe D, mais raccordé en XLR et avec des sources via un PC en USB sous serveur Daphile le rendu est à la hauteur!
Dommage qu'il n'y ai pas de télécommande. Réglage de volume bien pratique et éléctronique de précision. NOte: les sorties des deux dac ES9018 sont suivis d'étage à composant discret et d'aop suiveurs.
Qualité/prix au top
Depuis 3 semaines que je l'utilise, je ne lui ai pas trouvé de défauts.
J'attendais un DAC moins "feutré" que celui du Fostex HP-A8; je l'ai. Son rendu musical est plus précis, plus vif comme je l'espérais. Je l'utilise avec la partie ampli du HP-A8 pour les deux casques ED12 et Fostex TH900, et cela me convient très bien.
La finition est correcte, mais boîtier au design minimum; ce n'est pas un appareil pour le plaisir des yeux, mais celui des oreilles. A ce prix c'est déjà très bien.
Il me donne envie de le tester avec un ampli à tubes; sa précision doit faire merveille.....
