SA9027 + ES9023 24bits/96Khz Asynchronous USB DAC
DAC USB XDA2
Reference : 10572
32,90 €tax incl.
27,42 € tax excl.
Shipping from France
Billing in France
Technical support in France
This small DAC USB 24 bits 96Khz sober design is equipped with a USB Audio interface of modern entry Saviaudio brand renowned for its weak jitter. The decoding chip is the now famous ESS Sabre 9023 recognized for its simplicity of implementation and its musicality.
You will enjoy the attractiveness of modern dematerialized sources without sacrificing your current Hifi installation by plugging it into your stereo amplifier or dedicated headphone amplifier. Its asynchronous operation mode with its own internal clock provides a low jitter digital signal for high definition.
A smart device, easily transportable, perfect companion for a quality sound on its portable laptop PC to its audio amplifier or a headphone amplifier thanks to its stereo output in RCA-plated gold-plated RCA.
This easy-to-use USB DAC does not require a USB driver to install to run.
Note: This product is shipped naked (no USB cable or user manual).
Characteristics :
  • DAC mode: Asynchronous (Saber ES9023 has its own clock)
  • Interface USB: SA9023 (SAVIAUDIO): 16/24 Bit and 32Khz 44.1KHz, 48KHz, 88.2Khz, 96KHZ
  • Digital to Analog Converter (DAC): Saber ES9023
  • Input: USB-B 2.0
  • Analog Output RCA Stereo Plated Gold 24k
  • Signal Noise Ratio:> 95dB
  • Dynamic range:> 95dB
  • THD + N:> 0.006% (RL = 10 kΩ)
  • Supply Voltage: 5V (USB Power Supply)
  • No external power required
  • Dimensions 68 x 57 x 24mm (excluding RCA plugs)
  • Weight: 0.080kg
  • Connectors not included
  • Native / Plug & Play Mac OS, Linux, Windows XP / 7/8
[Img-14927-left-thickbox_default]
[Img-14930-left-thickbox_default]
DAC / ADC ChipES9023
Max sampling rate96kHz
