SMSL TV-DAC Audio converter S/PDIF to stereo analogue Jack 3.5mm
4.7 / 5
Reference : 10167
21,90 €tax incl.
18,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
SMSL TV-DAC
TV S-PDIF to Analog Converter Jack 3.5mm Stereo
smsl tv dac
A DAC for your TV
SMSL has designed this ultra compact and powerful DAC to let you enjoy the sound of your TV in high quality on your home analog audio systems.
The TV-DAC converts a Toslink coaxial or optical S/PDIF digital audio signal into a stereo analog audio signal that can be amplified in a classic way.
The converter is powered by the USB connector (plugged into your TV) and has a USB-A 2.0 port that allows you to add external storage without losing the original USB port of the diffuser.
Warning: it is necessary to adjust the output of your TV in stereo PCM.
ConverterWolfson WM8524
Sampling rate24bit 192kHz
Status indicatorLED
Line output level2.1Vrms
THD+N-89dB (-1dBFS)
Dynamic range104dB
SNR> 105dB
Crosstalk< -100dB
Frequency response20Hz - 20kHz at -0.5dB
Power Supply5V DC 500mA via USB-A (length : 20cm)
USB-A PortDedicated to storage devicese
Dimensions59 x 32 x 10mm
Weight20g
AccessoriesOptical Toslink and Coaxial to Jack 3.5mm Cable
smsl tv-dac
smsl tv-dac
OutputJack 3.5mm
DAC / ADC ChipWM8524
Max sampling rate192kHz
ColorGray
3 reviews
simple
salut
branché en premier sur un casque hum… ensuite sur un ampli là c’est beaucoup mieux, mais de tout façon le son des TV est aussi médiocre que leur HP……
ça se voit pas sur les photos du site mais sur l’autre face il y a des indications pour le sens des branchements
This review has been posted for SMSL TV-DAC Audio converter S/PDIF to stereo analogue Jack 3.5mm
pratique !
petit boitier simple a brancher, comme dis précédemment il fait le job. pour ma part je n'utilise pas les câbles d'origines mais du audioquest en coaxiale numérique via un petit adaptateur jack 3.5 stéréo vers 1 coaxiale.
attention toutefois il ne prend pas en charge les signaux muticanaux ni le stéréo en dolby digital par exemple. mais pour le prix honnêtement vous ne serez pas déçu !
Fait le job !
Micro boitier convertisseur qui se collera facilement sur le dos de votre TV avec un peut de sctotch double face.
Seulement 4 étoiles car il n'y a pas de câble Jack - RCA stéréo fourni (celui fourni est un câble mono !!). Je trouve ça un peu mesquin comme économie de la part du constructeur.
La qualité du son est très bonne et le tarif très abordable. Je reste satisfait de mon achat.
