MiniDSP NanoDIGI 2x8 B Audio Processor 28 / 56bit 2 to 8 channels
MiniDSP NanoDIGI 2x8 B Audio Processor 28/56bit 2 to 8 channels
4.5 / 5
Reference : 8451
195,00 €tax incl.
162,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
The nanoDIGI 2x8 B is a small digital processor in a gray anodized aluminum housing.
The nanoDIGI is equipped with SPDIF and Toslink (optical) inputs that can be selected from the software or the IR learning interface.
The internal sampling frequency converter adapts the digital input signal to the basic operating sampling frequency (44.1 to 192 kHz).
EFinally, the four SPIF outputs allow you to connect amplifiers, DACs or SPDIF devices up to 8 channels.
Like the other MiniDSP products, it is the plug-in that defines the capacity of the platform and therefore its sampling rate.
From 96 kHz to 192 kHz, the nanoDIGI is a unique, affordable, flexible processor.
This product is compatible with our infrared remote control 38kHz.
Features:/ Strong>
  • Supports up to 192 kHz depending on the plug-in used
  • Processor 28 / 56bit
  • Digital input signal: asynchronous Sample Rate Converter(ASRC)
  • Real-time control via USB
  • IR learning function
  • 5-24VDC
  • Dimensions: 75x75mm
What's in the box:
  • nanoDIGI 2 x 8B, assembled and tested
  • 1 x optical cable
  • 1 x miniUSB cable
  • 1 x Universal 5V DC power supply with interchangeable plugs for UK / EU / US / AU
DOWNLOAD A PLUG-IN FOR THE MINIDSP 2X8B FREE OF CHARGE:
For a full use of your MiniDSP product, it is necessary to have a plug-in.
There are several plug-ins available for download right here.
When receiving the product, you will receive in your package the method to follow to download the plug-in of your choice free of charge.
Interface presentation
Plug-in miniDSP 2x8
Download the documentation for the nanoDIGI 2x8B
Download the presentation of the nanoDIGI 2x8B
NanoDIGI 2x8B Owner's Manual
https://www.audiophonics.fr/images2/8451/8451_minidsp_nanodigi2x8B_dsp_4.jpg
https://www.audiophonics.fr/images2/8451/8451_minidsp_nanodigi2x8B_dsp_3.jpg
https://www.audiophonics.fr/images2/8451/8451_minidsp_nanodigi2x8B_dsp_2.jpg
https://www.audiophonics.fr/images2/8451/8451_minidsp_nanodigi2x8B_dsp_1.jpg
Also available in kit:
MiniDSP NanoDIGI 2x8K Audio Processor 28 / 56bit 2 to 8 channels
https://www.audiophonics.fr/images2/8446/8446_minidsp_nanodigi_2x8k.png
Max sampling rate192kHz
ColorSilver
8 reviews
jamais trop tard...
Acheté en juillet 2019 et mis en service aujourd'hui. Il pilote un sytème quatre voies. Là c'est du grandiose tout simplement. Pas facile à mettre en oeuvre, mais en procèdant progressivement , le résultat est prodigieux! Précision qui a toute son importance: tous les convertisseurs(SMSL, GUSTARD) viennent de chez AUDIOPHONICS, le site majuscule pour l'audio!
This review has been posted for MiniDSP NanoDIGI 2x8 B Audio Processor 28 / 56bit 2 to 8 channels
Un outil extraordinaire mais sensible
Le device est incroyable. Très puissant. Le problème est l'instabilité de la machine.
Si je touche l'entrée spdif pendant qu'i est sous tension et connecté au Dac externes. je perds la télécommande. Elle ne fonctionne plus. Je dois la reprogrammer .... J'ai mis un temps fou à trouver le problème.. Ne pouvant me passer de l'appareil j'en ai acheté un second et fait plein de tests. Jusqu'à trouver le problème. A ma connaissance de type de filtre actif numérique est rare... faut faire avec.
Dommage aussi que le plug in soit en 96Khz et pas 192.
perfect
The NanoDigi is a fantastic device that does everything flawlessly. I got a version with a black box which suits me even better.
All recommendations for the Audiophonics service, shipping was fast, delivery as well. Everything is perfectly packed and without the possibility of damage. Great job, keep it up.
Simple et efficace
Etant novice en matière de DSP j'ai acquis ce minidsp pour apprendre et me faire la main.
J'ai été rassuré par la simplicité de son plugin ainsi que son efficacité.
Je ne l'ai utilisé dans un premier temps que comme filtre afin d'intégrer le mieux possible un vieux, mais excellent caisson KLIPSCH SW12 II, au sein d'une paire de KLIPSCH HERESY III.
Je suis très satisfait du résultat.
Je verrai ultérieurement pour utiliser la partie égalisateur de ce minidsp.
Sa performance tient en partie à son traitement exclusivement numérique.
Pas de double conversion ADC et DAC dégradant inévitablement le signal traité.
Couleur boitier
Ca peut être et est secondaire, mais pourquoi ne commercialisez vos pas la version en boitier noir ? (je n'aime pas du out ce boitier blanc)
