ARMATURE Hecate XMOS Xcore 208 USB SPDIF Asynchronous Interface
Reference : 11412
199,00 €tax incl.
165,83 € tax excl.
Last items in stock !
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
FRAME HECATE XCORE 208
USB Interface SPDIF - 24bit / 192kHz - Asynchronous
Armature Audio Hecate
A USB interface with double galvanic isolation
The Hecate Xmos Xcore 208 Asynchronous USB / SPDIF Frame features the latest in high-resolution digital technology. This interface includes dual isolation galvanic isolation with 2x4 channels, guaranteeing the 1000 MIPS of computing capacity of the new processor XMOS Xcore 208, that is twice the capacity of the XMOS U8 older generation.
Thehas design quality of USB interface Armature Hecate uses the best electronic components. You can certainly say that you are in the company of one of the best USB interfaces on the market.
Xilink Processor
The original Xilink integrated processor which lowers the fully programmed output jitter allows very high resolution decoding on a 4-layer printed circuit board. Thelliance of the high-transfer galvanic bridge, the two Crystek low-noise phase oscillators provides analytical capability, enhanced readability for any quality 24 / 32bit DAC. Here is a USB / SPDIF interface that will renew your musical experience.
processeur Xilink
XMOS Xcore 208
XMOS Xcore 208
This state-of-the-art XMOS processor has 4 times the computing power of the old XMOS U8. The result: Greater definition combined with a very low jitter. XMOS Chips are a reference in this field and recognized time and again by the audiophile world.
High precision clocks CRYSTEK
The Crystek CCHD-575-25 22.57Mhz (multiple of 44.1Khz) and 24.57Mhz (multiple of 48khz) oscillators ensures a very low jitter rate and increased accuracy. The result is immediately audible with a very high definition without tension, a respect of the timbres wellabove the concurrent USB interfaces.
clocks crystek
The combination of the high-transfer galvanic bridge and the two low phase noise Crystek oscillators provides analytical capability and enhanced legibility for any high-quality 24 / 32bit DAC. Here is a USB / SPDIF interface that will renew your musical experience.
Discover the HECATE XMOS interface on the official website of the brand by clicking on the following logo:
Logo Armature
</ Tr>
ProcessorXilink with dedicated audio algorithm
USB InterfaceXMOS Xcore 208 1000 MIPS
Galvanic insulationDouble: current and digital
CompatibilityNative / Plug & Play on Linux UAC2, OS X
Status LEDsx3: Play, DSD, Power
Input Sampling Rate (XMOS Xcore 208)16 / 24bit up to 192kHz
Output Sampling Rate (SPDIF Coaxial Gold Plated)75Ω, 24bit and 192kHz max
Dimensions armature Hecate
OutputCoaxial SPDIF
Max sampling rate192kHz
Interface chipXMOS XCore U208
29 reviews
Que du Bonheur :-)
L'Hecate est connecté à un lecteur réseau Allo USBRIDGE Signature et à un DAC AUDIOPHONICS AK4495SEQ.
Après quelques déboires pour le configurer dans l'interface Web Allo DietPi, j'ai finalement réussi à modifier la "Soundcard" avec la valeur "Allo-Digione" (qui correspond à l'interface numérique chez Allo).
L'Hecate apporte indéniablement une amélioration, la scène sonore a plus de détail, un meilleur relief, tout est mieux positionné, un apport sur tout le spectre des bass à l'aigue
J'ai longtemps hésité mais je suis Ravie de l'ajout de cet Hecate dans mon système :-)
Encore un superbe produit proposé par Audiophonics.
This review has been posted for ARMATURE Hecate XMOS Xcore 208 USB SPDIF Asynchronous Interface
Super ddc
It makes me use my fanless PC and big screen all the time now. Clearly surpasses the sound from my ifi zen stream, by several steps. This is in the spirit of Alan Blumlein, who invented e.g. stereo, with the screen in mind. The only downside is max 24bit 192 kHz, so it can only handle 99.98% of all media.
Remember a USB-B Adapter Cable for DC 5.5 / 2.1mm Female Power Supply, also bought here, and some good clean 5v, not the 5v pc noise power;)
Provides full galvanic isolation.
This unit provides true galvanic isolation between usb input and the spdif output. It therefore prevents ground loops between PC and DAC (for instance) and that by itself gives a big inprovement in signal to noise ratio. Should be pointed out in the description.
Super produit
J'ai acheté ce produit pour remplacer ma vieille interface M2tech hiface 2 raccordée à ma sortie Nas en Usb. L'Armature Hecate se doit d'être rodée mais après le résultat est là. Cette interface va plus loin que m2tech :il semble qu'un voile à été enlevé. Un grand remerciement à monsieur David Aubert qui m'a orienté vers cet excellent produit et de surcroît bien moins cher que celui que j'avais repéré
Tres bien
Ecoute apres 50 heures de rodage.
Remplace ma "Xmos" audiophonics qui beneficiait deja d une alimentation externe stabilisee Audiophonics.
Cette hecate , sans cette alimentation extérieure, manque un peu de plénitude sonore , relativement a la vielle xmos (celle ci avec alim.stabilisée )tout en ayant déjà une meilleure spatialisation.
Avec l alim. Stabilisée, sa froideur initiale ( et relative) disparaît et les timbtres me semblent alors plus "analogiques',donc plus vraisemblables.
Belle et nette évolution donc au final de la xmos vers la Hecate.
P.S. j ai constaté aussi -sans grande surprise-que la qualite du câble d alimentaion de son alimentation stabilisee externe avait une incidence considerable sur la musicalité de cette hecate
