Schiit WYRD USB Decrapifier Isolateur USB
Schiit Wyrd USB Decrapifier Isolateur USB
Reference : 9033
149,52 €tax incl.
124,60 € tax excl.
Shipping from France
Billing in France
Technical support in France
Schiit WYRD USB Decrapifier USB Isolator
This isolator allows you to solve many problems related to the connection of converters in USB (noise of the switching power supply of the PC, weak power supply, etc ...).
What Is an Isolator and Why Do I Need It?
As its name implies, an isolator is used to electrically isolate data and / or power lines from a USB connector.
Theaim is to remove any electrical connection between the input and the output in order to avoidmaximum electrical and electrostatic disturbances to interfere with the Audio data.
Since the power supply available from a USB connector is very noisy and filtered drastically, it is not surprising to find remnants of audible noise in the final rendering.
And it's even worse with laptops!
Another problem regulated by this isolator is the appearance of loops of masseswhen connecting modules by usb.
You are not unaware of the impact these loops have on the audiovisual material ... The fewer the better, the better.
heprotects also your fixtures / fittings overvoltages,electrostatic discharges and other power rises likely to occur when the computer malfunctions (or in stormy weather ...).
Characteristics :
  • Made in USA
  • USB Ports: 1 Input (Type B) and 1 Output (Type A)
  • USB mode: USB 2.0 (480Mbps), USB 1.1 compatible
  • USB repeater: Controlled by a clock 20ppm (crystal oscillator)
  • Amperage available on USB: + 500mA
  • Supply Type: Linear with Low Noise Precision Controller (2.5uV)
  • Power consumption: 6W maximum, <1W typical (depends on the consumption of connected devices)
  • Comes with mains transformer but without USB cables
  • Dimensions: 130 x 90 x 40 mm
  • Weight: 900 g
