MOGAMI W2330
Great quality cable! Very fast delivery! Thanks audiophonics!
This review has been posted for MOGAMI W2330 Unbalanced interconnect cable 0.08mm² Ø3mm Great quality cable! Very fast delivery! Thanks audiophonics!
The MOGAMI 2330 cable is designed to be both strong and flexible.
This makes it particularly suitable for stage and studio use.
Features:
Configuration | ||||
Part No. | W2330 | W2333 | W2368 | |
No. of Conductor | 1 | |||
Conductor | Details | 16/0.08 A <T1000D*1> | ||
Size(mm²) | 0.08mm² (#28 AWG) | |||
Insulation | Ov. Dia.(mm) | 1.5Ø (0.059") | 1.0Ø (0.039") | |
Material | LNXLPE (Low Noise Cross - Linked polyethylene) | PVC | ||
Colors | Clear | White | ||
Served Shield | Approx. 36/0.12A | Approx. 38/6/0.08A | ||
Jacket | Ov. Dia.(mm) | 3.0Ø (0.118") | 4.0Ø (0.157") | 2.0Ø (0.079") |
Material | Flexible PVC | |||
Color | Black | |||
Roll Sizes | 100m (328Ft) 200m (656Ft) | 200m (656Ft) (standard) | 100m (328Ft) 200m (656Ft) | |
Weight per 200m Roll | 2.5kg | 4.2kg | 1.5kg |
DC Resistance at 20°C | Inner Cond. | 0.23Ω/m(0.070Ω/Ft) | ||
Shield | 0.05Ω/m(0.015Ω/Ft) | 0.10Ω/m(0.031Ω/Ft) | ||
Capacitance at 1kHz, 20°C (Partial C. Value) See below figure* | K0 | 115pF/m(35pF/Ft) | 350pF/m(107pF/Ft) | |
Inductance between conductors at 1kHz. 20°C | 0.3µH/m(0.092µH/Ft) | |||
Electrostatic Noise** | 50mV Max. | |||
Electromagnetic Noise** | 0.05mV Max. | 0.05mV Max. | ||
Microphonics at 50KΩ Load** | 300mV Max. | 1mV Max. | ||
Voltage Breakdown | Must withstand at DC 500V/15sec. | |||
Insulation Resistance | 100000 MΩ × m Min. at DC 125V, 20°C | |||
Flex Life** | 15,500 cycles | 16,500 cycles | 43,000 cycles | |
Tensile Strength | 255N | 284N | 206N | |
Emigration | Non-emigrant to ABS | |||
Applicable Temperature | -20°C‾ +70°C(-4°F‾ +158°F) |
Diameter (mm) | 3.0 |
Length (m) | Sold by length |
Number of conductors | 1 |
Insulation material | Other |
Shielding | Yes |
Section (mm²) | 0.08 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Ground / Shielding | Yes |
Average votes 4.8 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
POPOVSCHI B.
marco g.
marco g.
Jerome B.
István B.
