that we have undertaken with this product because we have developed a high-end multipair cable that is probably the best in the market today. This multi-purpose cable is intended for professionals who are ambitious and who are not accustomed to compromise in terms of linearity and protection. To optimize the sound, we have connected two opposite conductors in X ("Crossover"), which makes it possible to obtain a value of metric capacity cond./cond. incredibly low of 37 pF, therefore a virtually lossless retransmission, also over long distances. Connected in X, the SC-PEGASUS is even able to transmit digital signals (AES / EBU 110 Ohm). The short torsional torsion technique adapted to the linearity values and the use of very thin (0.05 mm) copper strands of oxygen-free copper guarantee a homogeneous and faithful sound and a high resistance to the alternating bending and a large longevity.
The SC-PEGASUS is equipped with awhich far exceeds the requirements normally required for a high-end multipair cable. It is protected by an overall shielding and by a shielding per channel, guaranteeing a 100% optical coverage. The overall screen is provided by a tubu braidcopper.
The conductors are shielded by a helical copper winding, assisted by a conductive aluminum foil. The SC-PEGASUS therefore not only has a screen against external disturbances, but the pairs of conductors are insulated and protected from one another. With SC-PEGASUS, you will acquire for many years the reference article on the cable market, plus the certainty that you will only have to deal with music and mixing.
USE :
Specifications: | |||
Constitution | [Xx (4LI2Y0,20mm2) (T) DY] CY | ||
Envelope, diameter | S-PVC 21,0 mm | ||
AWG | 24 | ||
Conductor inside | 8 x 4 x 0.20 mm2 / Ø 5mm (x8) | ||
Copper strands per core | 102 x 0.05 mm | ||
Insulation of the conductor | Foam / Skin-PE | ||
Protection | braid copper tinned (overall) + coil tinned copper + sheet AL / PT (pair) | ||
Optical cover | 100% | ||
Operating temperature | min. -20 ° C | ||
Operating temperature | max. 70 ° C | ||
Fire resistance per m | 1.93 kWh | ||
Weight per m | 538 g | ||
Color of envelope | black | Packaging, packaging unit | per meter |
Electrical Specifications : | |||
Capacity metric cond./cond. | (Crossover) 37 pF | ||
Metric Capacity Screen / Display | (Crossover) 76 pF | ||
Odometer Resistance, Conductor | <100 Ohm | ||
Resistance, insulation | > 20 MOhm | ||
Characteristic Impedance | (Crossover) 110 - 120 Ohm | ||
Reduction per 100 m (20 ° C) | 1 MHz: 3.2 dB | ||
Reduction per 100 m (20 ° C) | 10 MHz: 8.9 dB | ||
Reduction per 100 m (20 ° C) | 25 MHz: 14.6 dB | ||
Reduction per 100 m (20 ° C) | 50 MHz: 20.0 dB | ||
Reduction per 100 m (20 ° C) | 75 MHz: 24.3 dB | ||
Reduction per 100 m (20 ° C) | 100 MHz: 28.3 dB |
Diameter (mm) | 21.0 |
Length (m) | Sold by length |
Number of conductors | 8 |
Insulation material | Other |
Shielding | Yes |
