SQUERCABLE SC SQUARE 4 CORE MKII HIGHFLEX Modulation cable Ø6.5mm
SOMMERCABLE SC SQUARE 4 CORE MKII HIGHFLEX Modulation Ø6.5mm
Reference : 6138
2,30 €tax incl.
1,92 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
https://www.audiophonics.fr/images2/783/Square_schwarz.gifsymmetrical, 4-pole, crossover, studio
SOMMER CABLE - SC-SQUARE 4-CORE MKII HIGHFLEX
The master of acoustics ...
This maestro is a microphone cable of excellent quality, the result of all our skills. The conductor doubling ensures the optimization of the capacitive values ​​and the acoustic quality. This cable is often used in the studio as a phantom power supply or for the neutralization of background noise (in the latter case, the connection must be made in "X", ie the opposite conductors RED / WHITE and BLUE / YELLOW are connected together).
The blindadense copper helical geometry and a metallic fleece guarantee excellent anti-electromagnetic protection.
Fof its complex constitution, cable was founde often in high-quality hi-fi studios, where one appreciates the homogeneity and the linearity of its timbre.
If you are uncompromising "electric" or "musical", it will be your cable.
ADVANTAGES:
  • Excellent neutralization of background noise by the X connection of the 4 conductors
  • Can be used as a phantom power supply or as a stereo cable thanks to the two additional conductors
  • Excellent retransmission safety, excellent linear sound
  • Very robust, high tensile strength thanks to the reinforced PVC sheath
  • 100% shielding (copper dense helical and metallic fleece)
USE:
  • Professional studio and microphone technology
  • Connections for room or control units requiring a feedback signal
  • Professional MIDI technology, cable for overprinting devicess
  • High-end connection for hi-fi equipment
Specifications:
Constitution(4LI2Y0,20mm2) (T) DY
Envelope, diameter PVC 6.5 mm
AWG24
Conductor inside 4 x 0.20 mm2
Copper strands per core 102 x 0.05 mm
Insulation of the conducteurPE
Protectioncopper helical coil + conductive fleece
Optical cover100%
Operating temperature min. -25 ° C
Operating temperature max. 70 ° C
Fire resistance per m 0.22 kWh
Weight per m53 g
Packaging unit, packing unit yle = "font-size: small;"> roll 100/500 m
Colorblack
Electrical Specifications:
Capacity metric cond./cond.65 pF
Capacity metric cond./cond.(Crossover) 39 pF
Metric Capacity Screen / Display120 pF
Metric Capacity Screen / Display(Crossover) 78 pF
Odometer Resistance, Conductor<98 Ohm
have-size: small; "> Mileage resistance, shielding<20 Ohm
Resistance, insulation> 200 MOhm
Characteristic Impedance<95 Ohm
Diameter (mm)6.5
Length (m)Sold by length
Number of conductors4
Insulation materialPVC
ShieldingYes
Section (mm²)0.2
Ground / ShieldingYes
2 reviews
Cablage idéal pour platine TD.
Je l'ai utilisé pour ma platine TD doté d'un connecteur DIN coté bras de lecture: les voies droite et gauche utilisent chacune 2 fils, et le blindage du câble relie les châssis de l'ampli et de la platine TD.
Il y a ainsi une parfaite continuité du câblage, et aucune boucle de masse n'est possible.
Résultat, absence de ronflement, et la diaphonie apportée par le câble n'est pas décelable.
Montage idéal. De plus le câble est très bon marché
This review has been posted for SQUERCABLE SC SQUARE 4 CORE MKII HIGHFLEX Modulation cable Ø6.5mm
Pour sa neutralité
Petit câble fort sympathique plus typé studio. Branché sur une platine vinyle, le message est très riche avec beaucoup de subtilité. Manque juste un petit peu de chaleur pour moi. Câblé en X avec RCA WBT.
