RAMM AUDIO AMADEUS 7 MK2 Speaker Cable OCC Copper 2.62mm² Ø16mm
RAMM AUDIO AMADEUS 7 MK2 Speaker cable OCC Copper 13AWG Ø16mm
Reference : 12201
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 02-04-2024.
Shipping from France
Billing in France
Technical support in France
The speaker cable AMADEUS 7 MK2benefits from all the necessary attention and specificities. The goal of the American brand is to offer the best audio cable at the best price.
This speaker cable benefits from materials and manufacturing methods rarely used in this price range. Drivers are pure copper OCC six-body , and its insulating structure (Air Geometry Design) uses the air according to a geometry deposited by the mark itself.
This audiophile cable minimizes the distortion on the signal transmission thanks to its conductors in pure copper OCC, and its 6 cores all separated by its elaborate and sought-after construction. The whole is protected by a shield of Aluminum and polypropylene with multiple shielding, as well as a body in PVC to avoid any loss of transmission.
Here is the structure AMADEUS 7 MK2 - Air Geometry Design by Ramm Audio:
Structure câble AMADEUS 7 MK2
Features and Specifications:
  • Drivers in pur Copper OCC 13AWG (2.62mm²)
  • RAMM AUDIO proprietary insulation with air and polypropylene geometric structure
  • Protective screen Aluminum and polypropylene with multiple shielding
  • Cable construction around 6 separate cores
  • Offers excellent transparency and resolution
  • Dynamic and more defined bass
  • Can be used for bi-amplification or bi-wiring
  • Red PVC body with black nylon braid
  • External diameter: Ø 16mm
Diameter (mm)16.0
Length (m)Sold by length
Number of conductors6
Insulation materialPVC
ShieldingYes
Section (mm²)2.62
Ground / ShieldingYes
6 reviews
câble amadeus 7
Je rejoins tous les avis déposés sur l'amadeus 5 et 7.
Ce câble a réellement amélioré le rendu sonore et permet à mes atlantis lab de s'exprimer pleinement.
Patrick
This review has been posted for RAMM AUDIO AMADEUS 7 MK2 Speaker Cable OCC Copper 2.62mm² Ø16mm
Excellent câble pour enceintes acoustiques ,tres bon équilibre tonal ,pas d'agessivité , écoute agréable . Ce câble peut-être inclus dans toute chaîne HIFI ainsi que le haut de gamme et pour le tarif il serait dommage d'en faire abstraction.
Very good cable
Is thick, is good looking, it deliveries a good sound. Requires a little patience for building the final cable because every wire is insulated. And there are 2 very thin wires alongside copper in every coloured wire. So carefully with them. There is a very usefull tutorial on YT for building Ramm speaker cable. A good value for the money.
Une référence audiophile...
Très peu d'avis circulent sur ces Amadeus 7 MK II.
Je vais donc tenter de partager mon retour d'expérience sur ces câbles.
Ayant eut en prêt des Siltech LS-100 Classic bi-câblage pendant une année entière grâce à un ami, il était temps pour moi de les rendre et de me pencher sur ses remplaçants.
Mon système étant connecté en Transparent sur la grande majorité de la modulation, il me fallait trouver un câble neutre, s'associant parfaitement à elle.
Je me suis donc intéressé à la technologie présente dans les différents câbles.
Cherchant un modèle bi-câblage, les Amadeus 7 MK II ont retenues mon attention (section des conducteurs, blindage, type de cuivre...)
Une fois la commande reçu, je les aient monté avec des embouts en argent et des fiches bananes au rodhium.
Je les aient câblé en 4 conducteurs au lieu de 6 présents, comme sur les Siltech. Ramm Audio préconise de doubler les conducteurs pour le grave, mais sincèrement ce n'est pas nécessaire.
Il est à noté qu'il faut de la patience et être minutieux pour dénuder et monter l'ensemble.
A la première écoute, une scène ample et large viennent bousculer les Siltech LS-100. C'est impressionnant!
Mais l'expérience ne s'arrête pas là. L'ensemble joue plus dans le médium, ce qui flatte l'oreille, mais avec une douceur nettement supérieur aux Siltech.
Le grave est mieux tenue et bien mieux maîtrisé.
Le détachement des différents plans sonores, la profondeur de la scène sont accentués de manière significative.
Les timbres sont beaux et naturels donnant l'impression d'entendre les instruments plutôt que les enceintes, tout est transparent!
On dit qu'un câble donne 70% de sont potentiel à la première écoute, les 30 autres viennent au fil du temps.
J'ai trouvé ici mon bonheur, qui rend hommage à mes électroniques et à toute l'optimisation réalisée derrière.
Un produit résolument High-End qu'il faut soigner lors du montage pour en tirer tous les bénéfices et que je recommande.
Un référence audiophile!
Great cable
Amazing details!
