MOGAMI W2330 Unbalanced interconnect cable 0.08mm² Ø3mm
MOGAMI 2330 Balanced cable Ø 3mm
4.8 / 5
Reference : 9537
1,10 €tax incl.
0,92 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
The MOGAMI 2330 cable is designed to be both strong and flexible.
This makes it particularly suitable for stage and studio use.
Features:
  • Copper Conductor 0.08mm²
  • Polyethylene insulation
  • Double shielding: Copper spiral frame
  • Flexible PVC sheath
  • Outer diameter: 3mm
SPECIFICATIONS
Configurationdiagram unbalanced cable w2330diagram unbalanced cable w2333diagram unbalanced cable w2368
Part No.W2330W2333W2368
No. of Conductor1
ConductorDetails16/0.08 A <T1000D*1>
Size(mm²)0.08mm² (#28 AWG)
InsulationOv. Dia.(mm)1.5Ø (0.059")1.0Ø (0.039")
MaterialLNXLPE (Low Noise Cross - Linked polyethylene)PVC
ColorsClearWhite
Served ShieldApprox. 36/0.12AApprox. 38/6/0.08A
JacketOv. Dia.(mm)3.0Ø (0.118")4.0Ø (0.157")2.0Ø (0.079")
MaterialFlexible PVC
Roll Sizes100m (328Ft)
200m (656Ft)
200m (656Ft)
(standard)
100m (328Ft)
200m (656Ft)
Weight per 200m Roll2.5kg4.2kg
1.5kg
ELECTRICAL & MECHANICAL CHARACTERISTICS
DC Resistance at 20°CInner Cond.0.23Ω/m(0.070Ω/Ft)
Shield0.05Ω/m(0.015Ω/Ft)0.10Ω/m(0.031Ω/Ft)
Capacitance at 1kHz, 20°C
(Partial C. Value)
See below figure*
K0115pF/m(35pF/Ft)350pF/m(107pF/Ft)
Inductance between conductors at 1kHz. 20°C0.3µH/m(0.092µH/Ft)
Electrostatic Noise**50mV Max.
Electromagnetic Noise**0.05mV Max.0.05mV Max.
Microphonics at 50KΩ Load**300mV Max.1mV Max.
Voltage BreakdownMust withstand at DC 500V/15sec.
Insulation Resistance100000 MΩ × m Min. at DC 125V, 20°C
Flex Life**15,500 cycles16,500 cycles43,000 cycles
Tensile Strength255N284N206N
EmigrationNon-emigrant to ABS
Applicable Temperature-20°C‾ +70°C(-4°F‾ +158°F)
Diameter (mm)3.0
Length (m)Sold by length
Number of conductors1
Insulation materialOther
ShieldingYes
Section (mm²)0.08
Ground / ShieldingYes
6 reviews
MOGAMI W2330
Great quality cable! Very fast delivery! Thanks audiophonics!
This review has been posted for MOGAMI W2330 Unbalanced interconnect cable 0.08mm² Ø3mm
Used for interconnect - excellent flexibility
Flexible and fits good for Jack-RCA cables
RAS
Produit reçu vite et bien.
Rien à redire à part merci Audiphonics ;-)
breboistvan@gmail.com
Kiváló minőségű kábel. A vásárláskor éppen kifogyott a készlet, de megérte várni az új szállítmány beérkezését. Köszönöm a korrekt üzletet. Mindenkinek ajánlom a boltot. :)
