MOGAMI 2964 Coaxial cable 75 Ohm 0.23mm² Ø4.8mm
MOGAMI 2964 Coaxial cable 75 Ohm 0.23mm² Ø 4.8mm
Reference : 9838
2,20 €tax incl.
1,83 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
The MOGAMI 2964 coaxial cable 75 Ohm is designed to be tough and flexible at the same time.
Thus, it is particularly suitable for stage and studio.
Features:
  • Conductor Copper OFC 0.23mm²
  • 20 strands of 0.12mm²
  • Coaxial 75 Ohm
  • Insulation Low-noise polyethylene XLCPE
  • Double shielding: enclosed Spiral copper
  • 70 strands of 0.12mm²
  • Flexible PVC sheath
  • External Diameter: 4.8mm
  • This conductor with the cut is delivered to the linear meter, one ordered unit is equal to one meter delivered (the lengths are delivered in one piece)
CABLE SPECIFICATIONS
ConfigurationSubminiature Miniature Coaxial Cable w2381Subminiature Miniature Coaxial Cable w2422Subminiature Miniature Coaxial Cable w2895Subminiature Miniature Coaxial Cable w2546Subminiature Miniature Coaxial Cable w2300Subminiature Miniature Coaxial Cable w2964
Part No.W2381W2422W2895W2546W3200W2964
Characteristic Impedance50Ω75Ω75Ω75Ω50Ω75Ω
ConductorDetails20 / 0.10 Piano Wire
60 / 0.10A Served Cond.
1 / 0.20 Copper-Coverd Piano Wire17 / 0.08A7 / 0.14A50 / 0.12 OFC20 / 0.12 OFC
size0.047mm² (# 31AWG)0.03mm² (# 33AWG)0.085mm² (# 28AWG)0.107mm² (# 27AWG)0.565mm² (# 20AWG)0.226mm² (# 24AWG)
InsulationOv. Dia. (Mm)0.9Ø (0.035 ")1.05Ø (0.047 ")1.7Ø (0.067 ")1.95Ø (0.077 ")2.6Ø (0.102 ")2.6Ø (0.102 ")
MaterialXLPEXLCPEXLCPECPEXLCPEXLCPE
Overall ShieldTypeservedBraidedserved
DetailsApprox. 30 / 0.10AApprox. 39 / 0.10TA16/5 / 0.10A16/4 / 0.12AApprox. 70 / 0.12 OFCApprox. 70 / 0.12 OFC
JacketOv. Dia. (Mm)1.6Ø (0.063 ")2.0Ø (0.079 ")3.0Ø (0.118 ")3.3Ø (0.130 ")4.8Ø (0.189 ")
MaterialPVC
colorBlack / Red / Yellow / BlueBlackBlackGrayBlackBlack / Red / Yellow / Green / Blue
Roll Sizes305m (1,000Ft)50m (164 Ft) / 100m (328Ft) / 200m (656Ft)
Weight per 305m (1,000Ft) Roll1.5kg2.1kg4.2kg5.0kg3.0kg / 100m5.9kg / 200m
ELECTRICAL & MECHANICAL CHARACTERISTICS
Part No.W3200W2964
DC Resistance at 20 ° CInner Cond.0.035Ω / m (0.011Ω / Ft)0.090Ω / m (0.027Ω / Ft)
Shield0.025Ω / m (0.0076Ω / Ft)0.025Ω / m (0.0076Ω / Ft)
Capacitance at 1kHz, 20 ° C95pF / m (29.0pF / Ft)65pF / m (19.8pF / Ft)
Characteristic Imperdance at 10MHz50Ω ± 10%75Ω ± 10%
Attenuation (10MHz)0.061dB / m
(0.019db / Ft)
0.061dB / m
(0.019db / Ft)
Phase Constant (10MHz)0.31rad / m0.3rad / m
Electromagnetic Noise *0.1mV Max.
Voltage BreakdownMust withstand at DC 500V / 15sec.
Insulation Resistance10000 MΩ × m Min. HasDC 250V, 20 ° C
Flex Life *12,000 cycles16,000 cycles
Tensile Strength343N274N
EmigrationNon-emigrant to ABS resin
Applicable Temperature-20 ° C- + 60 ° C (-4 ° F- + 158 ° F)
StandardUL 1354 AWM VW-1 30V 60 ° C
w2964f1 diagram
w2964f1 diagram
Diameter (mm)4.8
Length (m)Sold by length
Number of conductors1
Insulation materialXLPE / XLCPE
ShieldingYes
Section (mm²)0.23
Ground / ShieldingYes
2 reviews
Vinyl
Câble de connexion pour platine tourne-disque très bien adapté. Grâce à sa section transversale, il est conçu de manière optimale pour les petits signaux avec d'excellentes valeurs de capacité.
This review has been posted for MOGAMI 2964 Coaxial cable 75 Ohm 0.23mm² Ø4.8mm
cable para tocadisco
Compre este cable para recablear mi Linn Axis y funciona muy bien, el trato de esta casa es muy cordial y fiables. Los envios son muy rapidos. Altamente recomendados. un saludo
