Neotech's leading high-tech hi-fi cable continues its investigation in the field of sound reproduction and today produces the ultimate in cable modulation, digital SPDIF, AES EBU, speaker and high- End.
The Solid Rectangular Core Silver Wire cable series enables the highest quality OCC UP cables to be manufactured with high-grade PTFE dielectric insulation.
You can now design OCC pure copper cables and access the High-End references of the audiophile cable market. The method of Professor Ohno of the Chiba Institute of Technology of Japan makes it possible to raise the purity of the 99.99998% pure copper and silver strands above the level of the standard annealed OFC cables.
The oxygen particles inside the copper strands are thus reduced to an insignificant level ensuring a high level of stability over time preventing oxidation over the long term.
The series of cables to be welded Neotech LECT UP OCC exists in differents diameters matching all expectations for the informed amateur building his own Hifi cables.This cable is particularly recommended for the assembly of high-end modulation cable.
Features:
Diameter (mm) | N/A |
Length (m) | Sold by length |
Number of conductors | 1 |
Insulation material | PTFE |
Shielding | No |
Section (mm²) | 0.2 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Ground / Shielding | No |
