VIABLUE H-FLEX Digital Optical Toslink Cable 1m
VIABLUE H-FLEX Câble Numérique Optique Toslink 1m
4.6 / 5
Reference : 905
91,00 €tax incl.
75,83 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
Toslink H-Flex ViaBlue cables are high-end optical audio cables that transmit digital signals using optical fibre technology. In this type of technology, electrical interference has no influence on the quality of the transmission. Toslink H-Flex cables provide a professional quality optical connection between high-end components such as amplifiers, CD/DVD decks, etc.
 The special fibre design for the waveguide used in Toslink H-Flex cables ensures maximum light source efficiency. These cables have a very high flexibility thanks to several machining processes used for the application of layers of insulation made of different materials, which allows very accentuated bending angles without increasing the attenuation rate. In the case of very large curvatures, the H-Flex optical fibre cable will transmit your data without any alteration.
The high quality waveguide is protected by a special flexible plastic compound. Another layer of very thin yet very hard plastic directly covers this compound to stabilize and fix the sensitive internal structure. Finally, a thick outer sheath protects these three inner layers from crushing and damage.
âToslink H-Flex cables are covered with a Cobra ViaBlue braid which provides additional external protection and an impressive external appearance. Equipped with Toslink H-Flex ViaBlue metal plugs, the ends of Toslink H-Flex cables are perfectly protected. The metal end caps up to the end guarantee stability over time and durable protection of the bare waveguide.
https://www.audiophonics.fr/images2/107/107_VIABLUEHFLEX.jpg
https://www.audiophonics.fr/images2/107/107_viablue_cable_toslink.jpg
Length (m)1.0
ShieldingNo
Section (mm²)N/A
ConnectorOptical Toslink
Conductors material (Cable)Optical Fiber
8 reviews
Joli cable
La qualité est visible, belles finition, livraison rapide. Très bon produit
This review has been posted for VIABLUE H-FLEX Digital Optical Toslink Cable 1m
exelent comparé a du coax argent
fixer sur ma platine cd musical fidelity x-ray et mon dac audio gd r28(r2r) j ai comparer l écoute entre coax et tos link. la sais autre chose..la spatialité la dynamique le naturel ..bref tout y est. .seul le grain et le piqué donne avantage a mon coax oayde.. pour prêt de 5/6 fois le prix. Apres le changement des embase rca avec des wbt argent .ont verra si sa reste aussi tenu dans la différence. mais sais déjà pas mal.. cet marque et peut être pas trop connue.. mais elle a de très bon résultat partout ou des ami l utilise.. a ne pas manquer.. pour un rapport q/prix très intéressant.. et made in allemande.
Qualité et musicalité excellentes
Le câble optique VIABLUE H-FLEX est très rigide et c’est tant mieux. Cela évite de plier la fibre optique en le manipulant. Il suffit de prendre une longueur de 2,50 m pour ne pas avoir de problème de branchement. A ce propos, les connecteurs sont d’excellent qualité, la fixation est parfaite, cela ne branle pas comme beaucoup de câble bas de gamme, voire haut de gamme.
D’un point de vue musical, la musique passe intégralement avec toute sa dynamique et tout son naturel. Aucune dureté, même sur de grosses formations orchestrales (test effectué sur des enregistrements de référence). L'image stéréo est en 3D. En résumé ce câble est meilleur que bien des concurrents vendus plus chers. Merci à Audiophonics de vendre des produits bien sélectionnés de très bonne qualité.
Le câble le coaxial CANARE est aussi une référence.
TRES BONNE MUSICALITE
Cette modeste évaluation s'adresse à ceux qui cherchent un câble optique de qualité et aussi aux sceptiques persuadés que tous les câbles numériques se valent. Sur ce dernier point, je suggère toujours d'essayer plusieurs câbles et de ne mettre à contribution que ses oreilles pour se convaincre des différences, parfois considérables, parfaitement perceptibles à une ouïe même peu entraînée! Commençons par l'aspect mécanique de ce câble optique VIABLUE H-FLEX pour déplorer se très grande rigidité. Il est concevable que le fabricant ait volontairement adopté cette conception afin de dissuader l'utilisateur de couder le câble, ce qui s'avère généralement fatal à la fibre optique! Compte tenu de ce point, on prendra soin de choisir un câble d'au moins 1 mètre car la version 0.5 mètre risque de vous confronter à d' insolubles problèmes de connexion. D'autre part, il faudra aménager un certain espace entre l'arrière de vos appareils et le mur. Sur un plan purement musical, ce qui est bien évidemment l'essentiel, ce VIABLUE se révèle être une belle surprise. Par rapport à l'excellent câble coaxial numérique CANARE (en vente sur ce site), le VIABLUE va peut-être encore un peu plus loin en transparence. Les timbres sont très naturels, d'une agréable véracité. Le soyeux des violons est préservé et les attaques du piano étonnent par leur très grande précision au prix toutefois d'une certaine atténuation du feutré, feutré que l'on perçoit mieux avec le coaxial CANARE. Les capacités de résolution du VIABLUE sont de premier ordre, les détails se perçoivent avec aisance sans accentuation gênante. La dynamique épouse le discours musical sans que l'on constate la moindre contraction, tout cela s'obtient sans aucune dureté, quelque soit le registre exploré. L'image stéréo, enfin, est tridimensionnelle avec toutefois une dimension atmosphérique légèrement moins "palpable" qu'avec le coaxial CANARE. En résumé, un câble très musical apte à satisfaire le mélomane, et une aubaine dans cette gamme de prix;
cable optique VIABLUE H FLEX
Ce câble s'avère d'une qualité d'écoute excellente au regard de son prix et même en comparaison à un câble numérique coaxiale argent valant 6 fois plus cher, mais il est un peu rigide.
