AUDIOPHONICS ARGOS8 Interconnect RCA Cable Pure Silver PTFE WBT-0110Ag 0.75m
Audiophonics Interconnect RCA Cable Full Pure Silver WBT-0110Ag 1.5m
By buying this product you get 64 loyalty points
Reference : 9775
649,00 €tax incl.
540,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
It is clear that the market of High fidelity today is not able to offer a real cable of modulation in pure Silver at a reasonable price.
Thus, we have designed and assembled in our workshops this cable in Silver from the conductor to the welds through the connectors.
Silver has the best thermal and electrical conductivity of all existing metals.
The result: an unusual cable with the highest IACS conductivity (106.9%).
This cable is especially for music lovers who want to upgrade their High fidelity system considerably.
Characteristics :
  • Conductor Pure Silver 99.99% Ø 0.8mm (2x0.5mm²), Braided shielding sheath 100% Copper 1-4mm Elecaudio
  • Insulation: 100% PTFE sheath Ø 1mm 18AWG and Silicon Fiberglass Sheath Ø3mm for each conductor
  • RCA Connectors Pure Silver WBT-0110Ag
  • Silver Solder Mundorf Supreme
  • 3: 1 heat-shrinkable sheath for optimum protection and maintenance
  • Nylon sheath PET ADIACIUM BG high resistance
  • Nylon sheath PET ViaBlue black tréssée
  • Splitters ViaBlue 100% Aluminum anodized black
Câble Audiophonics Argos8 RCA Argent
Length (m)0.7
ShieldingYes
Section (mm²)0.50
ConnectorRCA
Conductors material (Cable)Silver
3 reviews
Jeu égal avec cables ACSS
Ayant récemment fait l'aquisition d'un ampli AUDIO GD MASTER 10 MK2, relié à un dac Audio GD R8 j'ai pu comparer ce cable avec la connection ACSS des produits AUDIO GD.
Certes la sortie ASSS est plus plus puissante que la RCA, et comme l'ampli garde en mémoire le réglage volume, j'ai pu tester.
ACSS sur 20 et RCA sur 30....Résultat en fermant les yeux et en commutant de l'un à l'autre = STRICTEMENT AUCUNE DIFFERENCE.
Aussi bons l'un que l'autre.
Je vais donc envoyer la sortie DAC ACSS vers mon ampli casque AUDIO GD et la sortie RCA vers l'ampli.
L'inverse fonctionne très mal, son étouffé dans l'ampli casque..si Audiophonics pouvait m'éclairer.
This review has been posted for AUDIOPHONICS ARGOS8 Interconnect RCA Cable Pure Silver PTFE WBT-0110Ag 0.75m
Juste magique
Je reviens sur ce cable après quelques heures de fonctionnement.
Hier soir soirée tranquille. Un bon cognac, bien calé au centre des enceintes, tubes polarisés à 35ma pil poil, dac AUDIO-GD R8 calé en mode NOS je lance l'excellent album de JOSIENNE CLARKE - IN ALL WEATHER - Mastérisé en 24/96 khz.
Juste une voix bien posée à bonne distance du NEUMAN, quelques instruments à cordes, un peu de percussions, pas d'artifices ou d'effets spéciaux.
Je n'était plus chez moi, j'étais dans le studio devant elle.
Justesse du timbre de la voix, les filets de fin de phrases interminables, des micros détails en arrière plan que je n'avait jamais entendus.
Un son général, ni chaud, ni froid, juste naturel.
Bref, un cable qui se fait oublier et c'est le but.
Autre chose que je voulais dire est que mon dac que j'utilise en mode NOS 1, posséde 7 modes d’échantillonnage et j'avoue qu'avant il me fallait bien prêter l'oreille pour entendre les différences.
Avec ce cable, la difference entre les modes est flagrante et saute aux oreilles. Le mode NOS 1 reste mon préféré, car le plus neutre.
 (5)
Tout simplement magique
J'avais tellement lu et entendu de tout et son contraire sur le pure silver que je ne savais quoi en penser.
Et puis je me suis lancé, car au passage, même si ca peut paraître cher, le prix de ce cable est cadeau. Dans les magasins HIGH END, un cable RCA pure silver ca coûte entre 1500 et 2500 €.
Donc bravo à Audiophonics de fabriquer et vendre en direct.
Branchement et bin , la claque comme quand je suis passé d'un transistor à un tube.
J'avais un excellent cable tout cuivre, mais là tout est mieux.
Plus d'aération, des silences profonds, des médiums- basses plus articulés et plus de micros détails dans les aigus qui filent plus haut sans êtres agressifs....et encore ce cable n'a que 2 heures de fonctionnement.
Du coup, comme j'étais passé en bi-cablage en rajoutant un Viablue SC-2 au Mogami 3103 pour donner un peu de peps dans les aigus, j'ai remis le mogami tout seul et c'est juste PARFAIT.
A acheter sans modération et bravo au technicien qui monte les cables chez Audiophonics, c'est du beau travail bien fini.
Qobuzz HI-RES + Dac AUDIO GD R8 + Ampli tube LINE MAGNETIC + Enceintes TANNOY précision 6.4
 (5)
