Je l'utilise avec un Audio-GD R7-HE21. Tout est parfait de l'extrème grave à l'aigu, pas de dureté. Cable franchement excellent.
OFC Copper RCA Interconnect Cable Shielded Gold Plated 1m (Pair)
Sommercable's RCA Epilogue modulation cable has been designed to contribute to neutral and faithful sound reproduction, promoting a wide sound image thanks to excellent signal transmission. Ideal for sound professionals and recording studios, it is just as effective in a home HiFi system.
Thus, this Epilogue cable integrates high quality components. The outer sheath hides 4 100% insulated OFC copper conductors thanks to a triple shielding composed of a copper braid and semiconductor to limit the impact of interference on the signal. The conductors are smoothed with carbon for better conductivity. The cable design allows it to achieve a very low electrical capacity of 35pF, ensuring that there is virtually no loss over cable lengths of less than 10m.
The RCA connectors of this cable have PTFE insulation and are equipped with complex shielding. Its contacts are gold plated to ensure very good conductivity and resistance to oxidation.
Product type | Modulation cable |
Connectors | RCA |
Length | 1m |
Cable diameter | 7mm |
Conductor material | OFC Copper |
Sheath material | Pastic |
Shielding material | 3 layers : Braided Copper and semiconductor |
Capacity | 35pF wire/wire (crossover) |
Cable color | Yellow |
Quantity | Sold by pair (2 cable) |
Length (m) | 1.0 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | RCA |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Average votes 4.9 / 5 12 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Xavier P.
Laurent J.
Jean-Pierre f.
Pierre-Marin L.
Af O.
