VIABLUE NF-S1 Modulation Cable RCA Stereo 0.5m
VIABLUE NF-S1 Câble de Modulation RCA Stéréo 0.50m
4.3 / 5
By buying this product you get 23 loyalty points
Reference : 1513
236,99 €tax incl.
197,49 € tax excl.
Shipping from France
Billing in France
Technical support in France
This Viablue NF-S1 Interconnect cable reproduces music with high fidelity at all frequencies.
It transmits sound linearly and without distortions.
The two Silver-plated shielding screens preserve the most subtle variations of the signal and especially the high frequencies.
Its construction is of symmetrical type, ie it comprises 2 conductors instead of a single one in a coaxial cable.
Each conductor has 19 tinned wires with a diameter of 0.185mm or an equivalent section of 0.5mm².
The quadruple shielding consists of 2 films of ALU-PETP (Polyethylene terephthalate) and 2 silver-plated braids inverted to each other.
Cand superimposing different shields ensures a 100% overlap.
The outer diameter of the NF-S1 is 8mm
Viablue cables are equipped with gold-plated XLS connectors and insulated Teflon.
Capacity between 2 conductors: 50 pF core / core
Capacity between conductors and shield: 100 pF core / screen
Viablue NF-S1 review by HiFi-Choice
" In short, the NF-S1 is highly elegant and refined in both appearance and performance. "
Length (m)0.5
ShieldingYes
Section (mm²)0.50
ConnectorRCA
3 reviews
Très satisfait de ce cable modulation ,médium fluide et précis,basse sèche ,grave court et rapide ,assez neutre dans l ensemble ,a 94 euro je le trouve un peu chere je pense pour le prix quon doit trouver mieux.
This review has been posted for VIABLUE NF-S1 Modulation Cable RCA Stereo 0.5m
Ce câble s'avère vraiment excellent entre une source CD Creek EVO 2 et un ampli de même référence.
Le seul petit souci est de bien positionner le câble afin qu'il ne "sorte" pas de lui-même des plots RCA, car il est rigide et a donc tendance à faire beaucoup de "tirage".
Excellent cable, très neutre. Je redécouvre mes cds!!!
