ELECAUDIO FC105T Multistrand wiring cable Copper FEP 0.5mm² White
ELECAUDIO FC105T Fil de Câblage Cuivre FEP 0.5 mm² (Blanc)
4.8 / 5
Reference : 6431
1,90 €tax incl.
1,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
This single conductor cable is particularly suitable for internal wiring of devices. Thanks to its FEP dielectric insulation, it will be beneficial in any installation requiring high quality wiring that is resistant over time to higher temperatures, in particular for class A amplifiers.
Its structure of a 0.5mm² core made of OFC copper with fine strands (45 strands of 0,12mm) makes it a good choice at a studied price with a wide choice of color existing inf = "https://www.audiophonics.fr/fr/fils-de-cablage/elecaudio-fc105t-fil-de-cablage-cuivre-fep-05mm-noir-p-4658.html" target = "_ blank" >black,redor white for easy mounting.
Its stability over time and its electromechanical qualities make it a wiring element for countless installations.
It can be used tothe following cable elec-/ Span>
  • Multi-strand speaker cables
  • Analog modulation cables
  • Internal Wiring of High Fidelity Devices
  • Wiring for tweeters
Specifications:
    • OFC Copper
    • Insulating sheath in (FEP)
    • Resistance to heat: 200 °
    • Conductor Section:0.5mm²
    • Cable structure : 45 strands of 0.12mm
    • External Cable Diameter: 1.50mm
https://www.audiophonics.fr/images2/6431/6431_ELECAUDIOB.jpg
https://www.audiophonics.fr/images2/6431/6431_ELECAUDIOB_2.jpg
Diameter (mm)1.5
Length (m)Sold by length
Section (mm²)0.50
4 reviews
très bien
Câble semi rigide argenté de qualité. La gaine se dénude facilement et ne brûle pas durant le soudage. Capillarité parfaite pour la soudure. A découvrir pour le câblage d'un appareil audio de haut niveau.
This review has been posted for ELECAUDIO FC105T Multistrand wiring cable Copper FEP 0.5mm² White
Fil de Câblage Cuivre FEP 0.5mm²
Bon produit, idéal pour le câblage interne
Fil de Câblage Cuivre FEP 0.5mm² (Blanc)
Retour d'expérience,
Ce câble de bonne qualité se travaille bien, de plus l'isolant résiste à la chaleur du fer à souder
Produit recommandé
Très bien pour le câblage interne
