JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 2.2µF
JANTZEN AUDIO ALUMEN Z-cap Capacitor 2.2µF
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a more balanced presentation without the excessive brightness of other high-end capacitors exaggerating the upper parts of the audio spectrum.
Reference : 12085
43,90 €tax incl.
36,58 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Jantzen Audio Alumen Z-Cap Condensateur 100V 2.2µF
This series has a finer dielectric than other capacitors on the market. This avoids memory defects in the insulators for a fast transfer of electrons between each winding (very low resistance in ESR series). Janzen Audio Alumen capacitors are therefore particularly fast, offering harmonics worthy of the best oil paper capacitors, without the harmonic discolourations typical of the latter.
Jantzen Audio Alumen Z-Cap capacitors are therefore ideal for filtering high-end dome tweeters such as ScanSpeak Illuminator, Revelator, Dynaudio Esotec or SB Acoustics Satori. They are also ideal for Fountek NEO and Dayton AMT, ESS or RADIA tweeters. The welding wires are made of OCC Copper. These capacitors are also excellent for coupling in transistor amplifiers where the nominal voltage is sufficient (100VDC).
Product typeCapacitor
DielectricPolypropylene (PP)
DC Voltage100V DC
Tolerance+/- 3%
Max temperature85°C
Very low induction-
PolarizationNon-polarized capacitors
Very low resistanceESR
DimensionsØ22 x 80mm
Weight38g
Tolerance (%)3.0
Capacitor capacitance2.2
Rated voltage (V)100.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Belle amélioration
Sur des enceintes vintage de 1978-1980 (Optonica CP-4500H) remplace un Nichicon plastique (jaune) en série sur la ligne d'un tweeter. Ce condensateur a permis une belle amélioration de la précision et du réalisme de la scène sonore, offre une meilleure cohérence d'ensemble et a grandement abaissé toute dureté dans les aigus tout en donnant plus de précision dans ce registre.
C'est moins spectaculaire que le recablage de la semaine précédente (gain en dynamique et définition) mais bien plus que le changement de tous les autres condensateurs par des SCR MKP fait encore avant.
Ces constatations sont partagées par plusieurs personnes.
Dans l'ensemble je suis très content de cet achat, mes enceintes sont transfigurées alors que pas mauvaises à la base.
Bonne journée.
This review has been posted for JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 2.2µF
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium...
