JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 3.3µF
JANTZEN AUDIO ALUMEN Z-cap Capacitor 2.2µF
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a more balanced presentation without the excessive brightness of other high-end capacitors exaggerating the upper parts of the audio spectrum.
Reference : 12087
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 17-04-2024.
Shipping from France
Billing in France
Technical support in France
Condensateur 100V 3.3µF
Jantzen Audio Alumen Z-Cap Condensateur 100V 3.3µF
This series has a finer dielectric than other capacitors on the market. This avoids memory defects in the insulators for a fast transfer of electrons between each winding (very low resistance in ESR series). Jantzen Audio Alumen capacitors are therefore particularly fast, offering harmonics worthy of the best oil paper capacitors, without the harmonic discolourations typical of the latter.
Jantzen Audio Alumen Z-Cap capacitors are therefore ideal for filtering high-end dome tweeters such as ScanSpeak Illuminator, Revelator, Dynaudio Esotec or SB Acoustics Satori. They are also ideal for Fountek NEO and Dayton AMT, ESS or RADIA tweeters. The welding wires are made of OCC Copper. These capacitors are also excellent for coupling in transistor amplifiers where the nominal voltage is sufficient (100VDC).
This is the model with 100VDC 3.3µF values.
Product typeCapacitor
DielectricPolypropylene (PP)
Aluminium metallization99.99%
Capacity3.3µF
DC voltage100VDC
Tolerance+/-3%
Max temperature85°C
Very low inductance construction-
PolarizationNon polarized capacitor
Very low serie resistanceESR
DimensionsØ26 x 96mm
Weight52g
Tolerance (%)3.0
Capacitor capacitance3.3
Rated voltage (V)100.0
Capacitor typeFilm capacitor
Capacitor formatAxial
2 reviews
Surprise
Ce condensateur m'a permis par son équilibre de simplifier grandement le circuit de filtrage de mon tweeter.
Beaucoup d'espace, scène sonore réaliste, du relief, du placement plus facile des instruments, plus de lisibilité des instruments /chanteurs entre eux. Le meilleur Rapport Q/P que j'ai pu pratiquer à ce jour, face à du audyn cap jusque true copper, du mundorf, du scr jusque étain, et du jantzen jusque Silver z cap. Je n'ai pas testé les amber. Aussi je n'ai pas testé ce que donne ce modèle sur un mid, il semble qu'il soit fabriqué plus particulièrement pour gérer les fréquences hautes, donc les aigus.
This review has been posted for JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 3.3µF
alllumen z cap
On voit de suite la différence .Monté sur tweeter focal tc 120 tdx , ce dernier s 'est révélé.
Le prix peut paraître élevé , mais ce n'est rien en rapport avec la joie que le simple ajout de ce condensateur sur votre tweeter vous procurera. C'est un investissement a long terme lorsqu'on désire garder sa paire d 'enceinte. A avantageusement remplace un scr etain. tout y est et cela sans exagération ou fatigue auditive.
 (4)
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium...
