Hicon CM13-NTL RCA Connector Plated Gold Ø8mm (Unit)
Hicon CM13-NTL RCA Plug Gold Plated Ø 8mm (Unité)
Reference : 729
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Solid golden brooch for cable Ø 6 - 8 mm
The choice of a high quality RCA connector is imperative: Poor quality products are often afflicted with high contact resistance values ​​and can completely destroy the positive characteristics of a high quality audio cable.
Characteristics to be observed:
  • • Good surface protection - gold or other (some inexpensive connectors are only lacquered)
  • Massive pins, without riveting, crimping etc.
  • • Low contact resistance values
The HICON HI-CM09, HI-CM11 and HI-CM13 cinch connectors are equipped with a collet that ensures optimal contacts: After loosening the outer sleeve of the connector body, the plug is assembled with the plug and tightened outer sleeve. The pressure thus produced is so intense that the connector is practically unremovable without loosening the sleeve.
The excellent quality of the RCA series of HICON allows us to grant a 5 year warranty on these connectors!
Characteristics :
  • Gold Plated
  • Black
  • Maximum acceptable cable diameter: 8mm
  • Connector lockable by rotation of the body
  • Maximum Connector Diameter: 13 mm
  • Total Body Length: 44 mm
  • Sold individually
Legend
https://www.audiophonics.fr/images2/6155/RCA_DIMENSIONS.jpg
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticMale
4 reviews
Serrage efficace
Connecteur de belle qualité avec un bon rapport qualité /prix . Soudage plus facile que prévu,grâce aux bons conseils de David Aubert,que je remercie au passage.
This review has been posted for Hicon CM13-NTL RCA Connector Plated Gold Ø8mm (Unit)
Bon rapport qualité prix
Câblage et brasage aisés. Serrage sur les embases très efficace.
très bon rapport Q/P
pour le prix, elle fait très bien son job. RAS
un tres bon connecteur :tres haute qualite de de fabrication ,une fois la fiche verrouillee impossible de l'arracher ce qui offre ainsi un excellent contact
