ETI Spades Forks OFHC Copper Plating Gold Ø4.8mm (Set x4)
ETI Spades Fourches Cuivre OFHC Plaquage Or (set x4) Ø 4.8mm
Reference : 6784
89,00 €tax incl.
74,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
The ETI Spades® forks offer unlike most of their competitors, even those marketed as high-end significantly increased conductivity.
The vast majority of these connectors are made from nickel, gold brass or bronze / phosphorus alloy with a conductivity typically less than 28% IACS (International Annealed Copper Standard). By way of comparison, the high purity copper used in the vast majority of interconnecting cables has a conductivity rating of 100% IACS. Due to this low conductivity and the use of three disparate metals, the majority of standard RCAs, even expensive tend to decrease the performance of the components to which they connect.
The approachof ETI is radically different, the contact elements are machined in high purity OFHC copper (over 90% IACS) so as to ensure maximum conductivity (this allowing a gain of up to 320%).
Features:
  • Packing: 2 pairs
  • Contact Material: Copper OFHC
  • Gold plating directly applied to copper (no nickel, bronze or brass)
  • Fork spacing: Min: 5.9 mm Max 7.9 mm
https://www.audiophonics.fr/images2/6784/6784_ETISPADEGOLD_1.jpg
Mounting typeTo weld
ConnecticMale
Ronny
Un service exemplaire hors du commun . Félécitations à la société Audiophonics , ainsi qu'à ses colaborateurs et les agents des services des couriers Français et Belges .
This review has been posted for ETI Spades Forks OFHC Copper Plating Gold Ø4.8mm (Set x4)
