Viablue T6s Spade Plug Gold Plated 24K (Set x4)
High-class connectors.
Minimum resistance . Maximum quality .
ViaBlue T6s connectors are phosphor bronze and 24-carat gold-plated, with aluminum bodies. The ends of the T6s connectors are removable, allowing them to be interchanged between different models. This also means that only the terminal needs to be replaced in the event of damage. The cable ends are soldered to the terminal.
Max cable diameter (mm) | 9.5 |
Mounting type | To weld |
Connectic | Male |
Connector | Spade |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
