Excellente qualité de fabrication mais malheureusement non compatible avec les borniers de mes Dynaudio Spécial forty.
Spade Plugs 8mm Gold Plated 24K Ø5mm (Set x4)
ViaBlue TS forks screw onto the speaker terminals to provide a firm and durable contact between the speaker cable and the pole terminals. Connectors are supplied with an 8mm fork spacing. All TS plug connectors are protected from short circuits by a transparent insulating sleeve.
The speaker cables are easily and conveniently mounted in the ViaBlue TS plugs. All you need is a wire stripper to strip the cable and a 1.5mm Allen key to secure the cable in the plug. The speaker cable should be stripped to a length of about 8mm. It is then inserted firmly into the plug. The cable receptacle narrows inside the plug so that the passage of air is reduced when the cable is inserted correctly. This protects the cable strands from oxidation. The cable is easily fixed by the two large fixing screws, which gives it a very solid position in the plug. No soldering is necessary.
For better protection of the sensitive strands of high quality speaker cables against possible damage during attachment or against oxidation, it is recommended to use ViaBlue OFC copper ferrules.
Product type | Spades |
Spades opening | 8mm |
Contacts plating | Gold |
Short circuit protection | |
Max cable diameter | Ø5mm |
Connection type | To screw (M4) |
Body dimensions | 11 x 14 x 15.5mm |
Total dimensions of the contact | 16.5 x 14mm |
Max cable diameter (mm) | 6.0 |
Mounting type | To screw |
Connectic | Male |
Connector | Spade |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Thierry V.
ONDER O.
Jean-Michel C.
