FURUTECH e-TP60E 6-Port Gold Plated Plug
Furutech e-TP60E 6 ports power ditributor
The e-TP60E is a luxurious, sophisticated power distributor that eliminates the problems common to Audio-Video components and caused by polluted electrical current.
4.5 / 5
By buying this product you get 123 loyalty points
Reference : 2455
416,00 €tax incl.
346,67 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
A Hifi installation worthy of the name must have an arrival in irreproachable electric current.
Many home theater enthusiasts take great pains to carefully elaborate the main components of their system, but pay little attention to the source, alternating current.
Furutech knows that each part of the chain is as important as the final material, so maximum attention is given by Furutech on all aspects of AC transfer.
Explanation: Why this distributor?
The e-TP60E is luxurious and sophisticated, it is a power distributor that eliminates common problems encountered with audio-video components and caused by polluted electrical current.
Thehas waveform of the alternating current. becomes severely twisted by various sounds, tensions and sagging.
heThere are also devices which deform above and below the waveform of the current.
In addition, you are never alone; your residence shares with other apartments, houses, and businesses the same transformer.
That's why users who are keen on Audio and Video note that their systems are nicer at night or on weekends!
Features:/ Strong>
- Aluminum frames have been developedagainst another common problem, IFR (Radio Frequency Interference), and EMI (Electromagnetic Interference).
- The SCHUKO sleeves made of eutectic brass, processed by α (alpha) and 24k gold plated, are non-magnetic for stable, durable, optimized power transfer.
- The Furutech internal wiring is covered with Teflon (PTFE), which ensures low resistance.
  • Supply voltage: 220V 50 / 60Hz
  • Supported Current: 10A
  • Maximum power. 2500 W
  • 6 sockets SCHUKO Furutech Gold plated
  • Insulated internal wiring Teflon.
  • Dimensions: 200 x 128 x 61 mm
  • Weight: 0.98 kg
The final result :
Furutech's two-step cryogenic process and demagnetization
The cryogenic and degaussing processes of the alpha process aim to create the most optimized AC transfer.
Bright tonal colors and a deeper propagation at both ends of the frequency range.
Video devices of all types will display a resolution with less phantom image, less color shift, or "snow" appearance, or vertical and horizontal lines disappeared.
All electrical components are processed by FURUTECH (Alpha) Process (Super Cryogenic & Demagnetize Treatment), the bottom of the case is equipped with GC303.
Number of sockets6
FilteringNo
2 reviews
very good performance
Best price for this item in Europe
This review has been posted for FURUTECH e-TP60E 6-Port Gold Plated Plug
FURUTECH E-TP60E
Très bonne multiprise!! demande une petite période de rodage 50 heures.
SON: apporte un léger mieux. Note 14 sur 20
Video: La différence est extraordinaire!!! surtout lors de la lecture d'un blue ray !!! NOTE 16 sur 20
PS: l'ensemble des câbles sont des furutech TCS 31 avec prise furutech.
The e-TP60E is a luxurious, sophisticated power distributor that eliminates the problems common to Audio-Video components and caused by polluted...
