FURUTECH Flux-50 NCF (R) EMI AC-1501 (R) Filter sector Rhodium plated
FURUTECH Flux-50 NCF filter
By buying this product you get 228 loyalty points
Reference : 11335
1 149,00 €tax incl.
957,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
This model has been replaced by the Furutech Flux-50 NCF (G).
The New Flux-50 NCF features the Innovations Award winning FI-50 NCF power connector. They combine three “active” materials: Nano-sized crystalline, ceramic particles and powdered carbon. Nylon and fiberglass are incorporated as well forming an extremely effective, mechanically and electrically nonresonant connector body that may just be the most sophisticated in the world. And it incorporates the AC-1501R EMI-filtering with Neo Damper technology.
AC Power Can Make or Break Your System - The audio you hear from your home entertainment system is essentially the incoming electricity itself, and the typically violent storms riding the AC line and its ground is very detrimental to the performance of your components.
FURUTECH Flux-50 NCF Filtre secteur EMI AC-1501 (R) Plaqué Rhodium
The Flux-50 NCF is a sophisticated, luxuriously made and finished inline power filtering unit that eliminates many common problems caused by contaminated electrical power lines. It protects against distortion caused by ground noise, voltage spikes and sags, high frequency power supply noise from other components in your own system, plus high frequency digital noise from processors and digital interconnects.
Incorporated into select Furutech products, Nano Crystal² Formula - NCF is comprised of a special crystalline material that has two “active” properties. First, it generates negative ions that eliminate static and secondly, it converts thermal energy into far-infrared. Furutech then combines this remarkable crystalline material with nano-sized ceramic particles and carbon powder for their additional “Piezo Effect” damping properties.
The resulting Nano Crystal² Formula is the ultimate electrical and mechanical damping material – only found in Furutech products !
NCF Furutech Technologie
Characteristics :
  • For connection between power cables and power distributors or power cables and components. Eliminate and prevent radiated AC noise
  • Fitted with Furutech’s top-of-the-line Nano-sized Crystalline Piezo Ceramic rhodium-plated α (Alpha) nonmagnetic FI-50R NCF connector
  • AC-1501R EMI-filtering IEC, rhodium-plated α (Alpha) nonmagnetic copper alloy conductors
  • AC-1501R EMI filter features a parallel circuit with in-line coil and condenser, reducing noise at 1MHz by 10dB and at 10MHz by more than 30dB
  • Floating Field Damper (Earth/Ground Jumper System) US Patent No.: 6,669,491
  • Patent-pending metal cable clamp improves grip and reduces mechanically and electrically induced distortion
  • α (Alpha) conductor shield for protection against radiated noise
  • RoHS-compliant audio grade flexible PVC sheath improves vibration isolation
  • Special audio grade PE Insulation contributes to reduced capacitance
  • Incorporating Furutech’s special passive GC-303 EMI filtering material
  • Filter held in housing with resonance damping Piezo epoxy
Specifications Cable :
  • 62-strand α (Alpha) OCC conductor・0.127mm x 7 x 3 cores, 3.8mm diameter
  • Inner Sheath: RoHS-compliant audio grade flexible PVC incorporating carbon powder
  • Insulation: Special audio grade PE (Red/White/Green) 5.2mm diameter
  • Shield: 0.12mm diameter α (Alpha) Conductor wire braid
  • Sheath: RoHS-compliant audio grade flexible PVC (Purple red) 18.0mm diameter
  • Jacket: Nylon yarn braid approx. diameter 18.8mm
(Results clearly show Flux-50 NCF Filter reducing reduces noise, oscillation and resonance in the cable by a factor of 10, resulting in very natural and extremely fine resolution down and through the utterly silent noise floor)
Flux-50 NCF Power cable Construction
Length (m)N/A
Number of sockets1
FilteringYes
Rated current (A)N/A
2 reviews
Makes a difference!
Connected to power cable feeding preamp. Still burning in, but I can perceive the noise floor drop already.
This review has been posted for FURUTECH Flux-50 NCF (R) EMI AC-1501 (R) Filter sector Rhodium plated
Super Filtre !!!!!!!!!!!!
Ce filtre furutech a été placé en amont du bloc FURUTECH E-TP80, entre le cable secteur associé et l'entrée du bloc. Après une 100 Heures de rodage, le résultat est époustouflant.
Image stéréo plus précise, placement précis des instruments et présence de plus d'instruments, effet de présence renforcée (voix, piano, saxo, guitare, contre-basse, etc.), graves plus fermes et plus présents. Plus globalement, gain en dynamique et donc extension de la bande passante. "Musique" plus rapide, plus légère et plus fine.
Une TV 4K, une lecteur de Blu-ray et un ampli ampli audio-vidéo (Marantz SR5010) avec un pack d'enceinte B&W (Pack MT-50) sont branchés sur le Bloc FURUTECH : même effet pour le son (notamment, effet 5.1 très nettement amélioré), image avec plus de dynamique (les noirs sont encore plus noirs, images plus fines, effet de perspective nettement amélioré dans les images).
Je suis donc très très satisfait de ce filtre Furutech que je n'aurai sans doute pas acheté sans faire d'écouter préalable. C'est ce que j'ai pu faire grâce à un collègue qui venait d'en acheter un. Très net gain de qualité audio, malgré la présence préalable de nombreux équipements furutech et câbles blindés.
Equipements associés
Amplificateur intègré ARCAM A38, Amplificateur puissance ARCAM P38
Lecteur CD ARCAM CD17, Platine vinyle PROJECT 2 Xpression + Cellule Sumiko Blue Point N2, Lecteur réseau Cambridge Audio CXN (V2) Argent
Enceintes B&W CM 9
Câbles modulation : QED Réference 40, QED Speaker Cables Silver Anniversary-XT Bi-Wire (bi-amplification)
FURUTECH E-TP80 AC POWER Bloc Alim
FURUTECH FI-E50 (R), FURUTECH FI-52 (R), FURUTECH FI-48 (R), FURUTECH FI-E48 (R), FURUTECH FI-E38 (R) , FURUTECH FI-28 (R), FURUTECH FI-E11-N1 (R), FURUTECH FI-11, FURUTECH FI-8N (R) Connecteur IEC C7 2 pôles
YARBO SP-2200PW Câble secteur Cuivre plaqué Argent Ø11mm et OLFLEX 110CY Câble Secteur Blindé 3x2.5mm² Ø 10.3mm
