SMSL IVY DAC USB 16bit/48kHz for Android Smartphone OTG
50%
Reduced price!
Reference : 10939
Limited special offer
29,90 €tax incl.
-50%
14,95 €tax incl.
12,46 € tax excl.
Last items in stock !
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Here is the smallest DAC on the market, which plugs directly into your Smartphone before being connected via a 3.5mm headphone jack on your headphones. This converter is Plug & Play, that is to say that it is enough to connect it so that it is operational, no need of additional cable.
Particularly useful for people who want to improve the sound quality of their Smartphone, without being congested by larger DACs.
Its aluminum case is equipped with two volume control buttons to control the digital volume of Android.
WARNING ! Be sure to check the OTG compatibility of your terminal!
The use of DAC USB OTG requires a compatible application such as Hiby Music: Download Hiby Music
Characteristics :
  • DAC: BB PCM2704
  • Plug and Play OTG
  • Sampling rate: 32kHz / 44,1kHz / 48kHz
  • Signal signal noise: 95dB
  • THD + N: 0.009%
  • OTG Support: Android Smartphone (4.0 and above)
  • Control the volume of your phone
  • Power Supply: 0.5W / Vihas phone
  • Micro USB-B Male Plug
  • Headphone output: 3.5mm jack
  • Dimensions: 37 x 17 x 8 mm (when connected)/ Li>
  • Weight: 8g
  • Weight with hull: 27g
  • Housing black anodized aluminum
  • Supplied with its rigid shell: capable of receiving the DAC + a pair of intra auriculars
SMSL IVY DAC USB 16bit/48kHz pour Smartphone Android
(Compatible Smartphones)
OutputJack 3.5mm
DAC / ADC ChipPCM2704
Max sampling rate48kHz
