AUDIO-GD DAC-19 2017 PCM1704UK & DSP USB AMANERO 24bit 192kHz TCXO BNC
Audio-GD DAC-19 PCM1704UK & DSP 32bit 192kHz 10th Anniversary Edition
The DAC19 of Audio-GD, here in version 2017, achieves performances rarely equaled by a converter PCM1704UK.
KEY POINTS:
  • PCM1704UK
  • DSP Altera Cyclone
  • 24bits 192kHz
  • USB Amanero
  • TCXO 100MHz
By buying this product you get 89 loyalty points
Reference : 9747
899,00 €tax incl.
749,17 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
Audio-GD DAC-19
DAC / DSP / 24bit 192kHz / USB Amanero
Audio-GD DAC-19
Performances and rich musicality ...
After the DAC-19 in 2005, DAC-19SE in 2006, DAC-19MK3 in 2008 and DAC-19DSP in 2010, here is the DAC-19 PCM1704UK in its latest version.
Even if Audio-GD had already given it its nobility since 2005, the best technical engineers of the firm offer it here in its most accomplished form, with performances reaching a level that very rarely equaled.
This HiFi analog digital converter with recognized and approved results, received a Qobuzissime from Qobuz, excuse the bit!
Arrière Audio-GD DAC-19
A particularly efficient connection
The integrated PCM1704UK converter allows you to manage sources up to 24Bit / 192kHz. The DAC-19 has 4 inputs: BNC, RCA, Toslink Optics, and USB, as well as 2 analog outputs: RCA and ACSS.
Its SPDIF interface is extremelyt performance in data processing for better audio quality.
Great musicality and exceptional dynamics
24bit / 192kHz / USB AMANERO / TCXO / ACSS
Every product of the brand is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzers 2700 Series from Audio Precision.
The DAC-19 is equipped with an R-Core transformer, WIMA capacitors, and Date resistors. It is designed around the PCM1704UK and the Altera Cyclone DSP that work in parallel, as well as a Class A ACSS discrete circuit without any PDO with separate power supply.
Audio-GD DAC-19
TCXO 100MHz
TCXO - 100MHz
Usually the Audio-GD devices are equipped with the standard 80MHz clock, except this Audio-GD DAC-19 includes the option TCXO Ultra Low Jitterof 100MHz. This TCXO (Temperature Compensated X (Crystal) Oscillator) clock is more precise and significantly reduces the jitter.
PCM1704UK
This analog digital converter makes use of the R2R conversion which consists in directly using the bits of the digital signals to reconstruct the analog signals, all this acting on a network constituted solely of resistors having a given value (R) and its double (2R ), without going through an over-sampling phase.
PCM1704UK
SNR<108dB
THD<0.0005%
Frequency Response20Hz - 20kHz (-0.5dB)
Max Output Level2mA (ACSS) / 2.5V (RCA)
Output Impedance10Ω
Input sensitivity0.5Vp-p (Coaxial, 75Ω) / 19dBm (Optical)
Supported sampling ratesUSB up to 192kHz / Coaxial up to 96kHz / Optics up to 96kHz
<inputs/ Td>BNC / RCA / Optical Toslink / USB Amanero (iPhone / iPad compatible via Camera Kit)
ExitsRCA / ACSS
Miscellaneous
Consumption16W
Weight5kg
Housing material100% Anodized aluminum
Dimensions320 x 240 x 80mm
AccessoriesPower cable
5 reviews
Conseil !
Bonjour,
Voici un petit conseil d'utilisation.
Si vous écoutez essentiellement des CD ou des fichiers FLAC, il faut impérativement configurer ce DAC en NOS et là, vous obtiendrez le meilleur de cette machine : que de beauté, davantage de scène sonore, plus de détails, plus d'aération, les enceintes gagnent alors une nouvelle jeunesse ! C'est tout simplement splendide.
Mais si vous écoutez essentiellement des mp3, alors laissez la configuration de base et les fichiers de faible qualité seront alors plus agréables à l'écoute.
Voilà, si vous suivez ce conseil, vous serez un utilisateur heureux.
This review has been posted for AUDIO-GD DAC-19 2017 PCM1704UK & DSP USB AMANERO 24bit 192kHz TCXO BNC
Plénitude
associé à un Sony CDP 557 es transformé en drive pur (sortie spécifique 75 ohm ajoutée), je combine la dynamique et les timbres du transport de légende du Sony à la finesse et l'aération du DAC.
Un ensemble d'exception qui écrase tout à plusieurs fois son prix.
La précision et le détail obtenus permettent de facilement tester câbles de liaison et secteur pour aller encore plus loin.
Fiabilité d'Audiophonics assurée comme d'habitude.
Le chainon manquant
Rapport qualité prix certainement imbattable, j'ai peu d'expérience en matière de DAC, mais celui ci a transfiguré mon système, basses tendus, propres, les voix à se retourner pour vérifier que vous êtes seul dans votre salon.
Une dynamique excellente sur toutes les fréquences, des aigus liquides non crispés, certainement le meilleur choix à ce tarif. A tester absolument.
Merci Audio Gd et Audiophonics.
Paul
un seul mot : somptueux...!
Excellent
Résultat sonore équivalent avec un lecteur de cd valant 4 fois son prix!
The DAC19 of Audio-GD, here in version 2017, achieves performances rarely equaled by a converter PCM1704UK. KEY POINTS: PCM1704UK DSP Altera...
