AUDIO-GD NOS 19 DAC PCM1704UK & DSP USB AMANERO FIFO 384KHz Black
AUDIO-GD NOS 19 2016 DAC PCM1704UK Asynchronous AMANERO FIFO 384kHz
The Audio-GD NOS-19 Edition 2016 is equipped with an updated DSP, a NOS mode and an additional clock for high-quality sound reproduction.
KEY POINTS:
  • Asynchronous
  • USB Amanero
  • DAC PCM1704UK
  • DSP Altera Cyclone
By buying this product you get 94 loyalty points
Reference : 10782
949,00 €tax incl.
790,84 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
AUDIO-GD NOS 19 Black
DAC Asynchronous / DSP / 384kHz / USB AMANERO
Audio-GD NOS 19 Noir
Very High Fidelity ...
The DAC-19 is back in version 2016 (and NOS mode), with an update of its DSP and an additional clock dedicated to the management of asynchronous transfers, it is now able to manage sampling rates records: up to 384kHz.
Meme if Audio-GD had already given its letters of nobility since 2005, the best technicians of the firm we offer it here in its most accomplished form with performances uncommon.
<p> This HiFi analog digital converter with recognized and approved results has receivedref = "http://www.qobuz.com/FR-en/info/Hi-Res-Guide/Benchs-d-assay/Audio-gd-DAC19-and-de-trois177606" target = "_ blank">Qobuzissime from Qobuz, excuse the bit!
Oversampling modes and a "NOS" mode
The novelty concerns the mode without Oversampling "NOS". The DSP 1 includes two distinct operating modes. This new DSP makes it possible to get rid of the noise problems associated with NOS mode by keeping its advantages in terms of musical pleasure thanks to a filtere -6dB not destructive.
Mode 1 favors the speed of data transfer, the second allows processing on DSP FIFO with algorithm.
A particularly efficient connection
The integrated PCM1704UK converter allows you to manage sources up to 384kHz. The NOS 19 has 4 inputs: BNC, RCA, Toslink Optics, and USB AMANERO, as well as 2 analog outputs: RCA and ACSS.
Its SPDIF interface is extremely powerful in terms of data processing for better audio quality.
Back Audio-GD NOS 19 Black
Great musicality and exceptional dynamics
384kHz / USB AMANERO / TCXO / ACSS
Every product of the brand is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzers 2700 Series from Audio Precision.
The NOS 19 is equipped with an R-Core transformer, WIMA capacitors, and Date resistors. It is designed around the PCM1704UK and the Altera Cyclone DSP that work in parallel, as well as a Class A ACSS discrete circuit without any PDO with separate power supply.
Audio-GD NOS 19 high
100MHz TCXO
TCXO - 100MHz
Usually the Audio-GD devices are equipped with the standard 80MHz clock, except this Audio-GD NOS 19 includes the TCXO Ultra Low Jitter option of 100MHz. This TCXO (Temperature Compensated X (Crystal) Oscillator) clock is more precise and significantly reduces the jitter.
PCM1704UK
This analog digital converter makes use of the R2R conversion which consists in directly using the bits of the digital signals to reconstruct the analog signals, all this acting on a network constituted solely of resistors having a given value (R) and its double (2R ), without going through an over-sampling phase.
Class A
<! - CHARACTERISTICS SECTION ->
SNR109 dB (22Hz - 22kHz)
THD<0.0008% (20Hz - 20kHz)
Frequency Response20Hz - 20kHz
Max Output Level2mA (ACSS) / 2.5V (RCA)
Output Impedance10 Ohm
Input sensitivity0.5Vp-p (Coaxial, 75 Ohm) / 19dBm (Optical)
Supported sampling rates(44.1kHz, 48kHz, 88.2kHz, 96kHz) / Optical (44.1kHz, 48kHz, 88.2kHz, 96kHz) / Coaxial (44.1kHz, 48kHz, 88.2kHz,
inputsBNC / RCA / Optical Toslink / USB (AMANERO USB port compatible iPhone / iPad via Apple Camera Kit)
ExitsRCA / ACSS
Various
Consumption16W
WeightAbout 5kg
Housing material100% Aluminum
ColorBlack anodized
Dimensions320x240x80mm
AccessoriesPower cable / USB cable
12 reviews
Sublimissime!
Bought this DAC to use on my Meridian player and connect digital TV, streaming. Great sounding and very nice depth, harmonics in the soundstage. What can 44.1kHz (NOS) be great, just like that, simply it is sublime. Thank you Audiophonics and mr Kingwa. I can play a bit with the preferences but the standard is already great. The Qubosissime helped me make the choice, and I'm not disappointed. Next step: subscribe to Q and attach a streamer.
This review has been posted for AUDIO-GD NOS 19 DAC PCM1704UK & DSP USB AMANERO FIFO 384KHz Black
Zero déception
Il faudra attendre quelques dizaines d'heures d'écoute avant de confirmer mes premières impressions, mais je retrouve le plaisir d'écoute que j'avais sur mon lecteur Rega Jupiter. Pour le moment, connecté directement derrière un NAS Synology, via des cables ad-hoc (Audiophonics aussi) et l'usage du soft DS Audio. Cette config est simple, mais perfectible, il faudra mettre entre les deux un "player" sans DAC ...
Remarquable !
Appareil inspirant confiance et présentant un excellent rapport qualité/prix. Supérieur au convertisseur précédent (carte optionnelle) sur les critères de profondeur et de scène sonore. Les instruments sont mieux détourés, ce qui facilite l'immersion dans l'action qui se déroule devant vous ... Et encore, les premiers essais ont été effectués avec un câble coaxial à 7 € ! J'attends donc avec impatience mon Canare double RCA qui le remplacera avantageusement (le précédent DAC ne permettait qu'une connectique BNC). Petit bémol qui n'entache en rien les nombreuses qualités de l'engin : l'absence de sérigraphie qui aurait pu permettre de distinguer un DAC de l'autre parmi les nombreux modèles proposés. Sinon, il faut ouvrir les entrailles de la bête ... J'ajouterai une livraison rapide en Belgique (5 jours de délai depuis la commande). Merci donc à Audiophonics.
Fabuleux
Mes enceintes ont mutée, des basses tendues et un aigu articulé, un son analogique, une précision et une transparence somptueuse, l'impression d'être devant les musiciens... Ce Dac remplace un Dac Rega : le gap est immense, il me semble bien supérieur au Saturn-R, Je suis passé de Toslink à USB car l'entrée USB est bien meilleures que Toslink surtout au niveau de la tenue des basse. L'entrée Coax est très bonne aussi. Je passe mon temps à réécouter mes CD que je redécouvre comme si je ne les avais jamais écouté... Mon ampli est un BC Acoustique 362D (qui ressemble un peu au Master 10) et les enceintes des petites Proacs avec Audirvana comme source.
 (3)
Superbe matériel.
Bonjour,
Actuellement en possession de ce DAC depuis une semaine.
Avant de porter un jugement sur celui-ci, je préconise au minimum d'une centaine d'heure à le faire fonctionner sur une webradio, par exemple. Je dirais même que c'est obligatoire.
Après cela, muni d'un bon câble secteur à un prix cohérant (ex: Elecaudio CS-361B) et un cable USB un tant soit peu qualitatif, cet Audio GD DAC19 surpasse en musicalité mon ancien couple composé d'un DAC Hegel HD11 + interface Audio GD DiU8.
Ca boxe pas dans la même catégorie. C'est dit!
Pour lui trouver un concurrant, il faudrait le comparer à un Hegel HD25 tellement le GAP face au HD11 est évident.
Ces puces PCM1704 apporte un grain, une matière à la musique juste fantastique. Pourtant il est bon cet HD11. Les tests sur la toile sont unanymes.
Les conséquences à l'écoute ont pour effet de percevoir la scène sonore très épaisse, vobile avec une meilleure dynamique et sans le moindre stress.
C'est bien plus riche en harmonique et détails.
Un grand merci à toute l'équipe d'Audiophonics qui encore une fois est d'excellent conseil.
Je suis enchanté de mon achat!
The Audio-GD NOS-19 Edition 2016 is equipped with an updated DSP, a NOS mode and an additional clock for high-quality sound reproduction. KEY...
