FiiO M3 Ultra compact HiFi DAP DAC 24bit/96kHz 8Go
FiiO M3 HiFi DAP DAC DSD32bit/384kHz 8G
Reference : 10479
67,90 €tax incl.
56,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
DAP, the FiiO M3 is the miniature digital music player of the brand that has already proved its know-how in the field with its predecessors.
Ultra compact and extremely light, it is equipped with a TFT screen of 240x320p (2 ").
It is easily imposed in the category of DAPs whose interface FiiO Music is very pleasant to use and particularly intuitive.
It can also be used as a quality USB DAC to enjoy your audio sources on your home audio systems.
It is a HiFi player capable of playing almost all audio formats up to 24bit 96kHz (APE / FLAC / ALAC / WMA / WAV / MP3).
Characteristics :
  • DAC Cirrus Logic CS42L51
  • Files without loss supported: APE (16bit 48kHz), WAV (24bit 96kHz), FLAC (24bit 48kHz)
  • Supported compression files: MP3, AAC, WMA, OGG, M4A, ALAC
  • Memory (ROM): 8GB (up to 64GB via microSD not included)
  • Impedance Recommended headphones: 16 to 100 Ohm
  • Analog output / headphone output: 3.5mm jack
  • Micro USB 2.0 port
  • Output Impedance: <0.4 Ohm (32 Ohm)
  • 5-band digital equalizer (+/- 6dB) integrated
  • Volume control: 60 levels
  • THD + N headphone output: <0.008% (1kHz)
  • Frequency response: 20Hz - 20kHz
  • Crosstalk :> 70dB at 1kHz
  • Signal Noise Ratio:> 95dB
  • Output voltage max:> 2.8 Vp-p
  • Power Supply: 5V DC 500mA recommended
  • Battery capacity: 550 mAh
  • Autonomy: 24h
  • Charging time: 2.5 h
  • TFT screen 2 "/ 240x320p
  • Output power 1:> 50 mW under 16Ω THD <1%
  • Output power 2:> 30 mW at 32Ω
  • Weight: 40g
  • Dimensions: 74x39.7x9.1mm
  • Comes with headphones, cord and micro USB to USB-A cable
[Img-14303-left-thickbox_default]
[Img-14304-left-thickbox_default]
[Img-14305-left-thickbox_default]
[Img-14306-left-thickbox_default]
[Img-14307-left-thickbox_default]
[Img-14309-left-thickbox_default]
[Img-14310-left-thickbox_default]
[Img-14311-left-thickbox_default]
[Img-14312-left-thickbox_default]
[Img-14313-left-thickbox_default]
[Img-14314-left-thickbox_default]
[Img-14315-left-thickbox_default]
