HIFIMAN SUPERMINI Digital Audio Player HiFi Balanced DSD 24bit/192kHZ
HIFIMAN SUPERMINI Digital Audio Player HiFi Balanced DSD 24bit/192kHZ + RE-600
By buying this product you get 39 loyalty points
Reference : 11284
399,00 €tax incl.
332,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Here is the DAP SUPERMINI, the brand new HIFIMAN ultra compact audiophile player. The latter weighs only 70g for 8.5mm thick, as much to say that it was designed to follow you everywhere and at every moment.
Indeed, its long battery allows you to enjoy your music up to 24bit / 192kHz for 22h. The SUPERMINI also decodes your music formats DSD (DSF, DFF), which makes him a high fidelity music player par excellence.
It has 2 Jack outputs: a "Normal" and a "Balanced" (Symmetrical) to perfectly match the intras or the headphones you will use with. Thus the combination of the two will give you irreproachable and high quality sound results.
In order to be directly operational, you will receive with your SUPERMINI symmetrical in-ear headphones, also from HIFIMAN. The latter are a reference in the category of high fidelity intras.
Features:/ Strong>
  • Sampling rate: up to 24bit / 192kHz
  • Frequency response: 20Hz - 20KHz
  • THD: 0.04%
  • Noise Ratio: 102dB (to +/- 3dB)
  • Autonomy: up to 22h
  • Outputs: 320mW @ 32Ohm (balanced output)
  • SD card slot: TF Card up to 128Gb
  • Display Size: 2 "(OLED)
  • Supported Music Formats: WAV / FLAC / AIFF / APE / MP3 / OGG / AAC / WMA // Li>
Packaging:
  • Dimensions DAP: 104x45x8.5mm
  • Weight: 70g
  • Black color
  • Black Balanced In-Ear Headphones
  • Comes with a USB-A to Micro USB-B cable
  • Instructions for use supplied (In English)
HIFIMAN SUPERMINI DAP DSD
Hifiman Supermini DAP DSD
