SHANLING M2 Space Grey DAP DAC CS4398 32bit/192kHz DSD
Shanling M2 Black DAP DAC CS4398 32bit/192kHz DSD
Reference : 10622
249,00 €tax incl.
207,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
The famous firm here unveils the compact DAP of its range of high fidelity players: the Shanling M2.
Surprising in efficiency and designed around a sober and elegant design at once, it is as comfortable as DAP, as a sedentary Audiophile or DAC USB source.
It's a full-featured Hi-Fi player that gives you the ability to play almost all high-resolution PCM files up to 32bit 192kHz or DSD.
heuses a Cirrus Logic CS4398 converter and a combination of new components (low-pass filter MUSE8920 3.5V low voltage, AOP TPA6120A2 headphone output) resulting in great musicality.
The Shanling M2 is a compact DAP with reflective and neat electronic architecture.
It is a very good value for money.
Its very ergonomic design makes it a successful product that represents an alternative to larger digital players.
Test of the Shanling M2 by Nomad.
Features:/ Strong>
  • DAC Cirrus Logic CS4398
  • USB DAC function
  • Taux supported: 32bit 192kHz, including the 88.2kHz
  • Supported Audio Files: APE, FLAC, ALAC, WMA, AAC, OGG, MP3, WAV, AIFF, DSF, DIFF, DSD
  • Headphone amplifier: TPA6120A2
  • Low-pass filter CCR MUSE8920 low voltage (3.5V) on DIP8 support
  • Frequency response: 20Hz - 20kHz to -0.5dB
  • THD + N: <0.004%
  • Signal Noise Ratio (SNR):> 102dB
  • High precision clock (jitter: 200fs)
  • Analog volume control via ALPS potentiometer
  • Digital Equalizer
  • Output Level: 1.3Vrms
  • Output power: 125mW under 32 Ohms, 13mW at 300 Ohms
  • Impedance: 32 - 300 Ohms
  • 2.4 "TFT screen
  • External memory: Micro SD up to 128 Giga (not included)
  • Micro USB port
  • Output Jack 3.5mm: Headphone (amplified), line (not amplified)
  • Battery: 2200mA / h
  • Autonomy: 9 hours
  • Dimensions: 110x52.5x13.8mm
  • Weight: 115g
  • Chassis Aluminum, Carbon finish
  • Space Gray Anodized
  • USB A to Micro USB cable, 3.5mm to S / PDIF RCA coaxial cable, USB stick adapter for micro SD card and supplied cover
  • Compatible with Mac OS 10.7 and Linux without drivers and Windows XP, 7, 8 (driver nécessaire)
M2 "href =" http://www.head-fi.org/products/shanling-m2-hifi-portable-lossless-musicl-player-dsd-player/reviews/14446 "target =" _ blank ">Head-Fi
Test in English (Click here).
[Img-15240-left-thickbox_default]
[Img-15242-left-thickbox_default]
[Img-15229-left-thickbox_default]
[Img-15231-left-thickbox_default]
[Img-15238-left-thickbox_default]
[Img-15230-left-thickbox_default]
Bon baladeur Hifi
Petite rectification par rapport à la description: il n'a pas de mémoire interne, testé avec carte micro SDXC 64GB class10 Samsung formater en exFAT. Il fonctionne très bien, menu intuitif, pour le faire fonctionner en DAC sous Seven il faut installé le driver version 1.61.0. Je branche un adaptateur 'jack/RCA' sur l'interface Line LO du baladeur sur entrée RCA AUX de mon ampli et en avant la musique. Testé musique MP3-Wave-DSD128-Flac. L'autonomie de la batterie est de 10H. Je suis très satisfait de mon achat.
This review has been posted for SHANLING M2 Space Grey DAP DAC CS4398 32bit/192kHz DSD
